@Hohn I took these pictures of an overhauled John Deere 6.6L engine that had stuck oil control rings and severe bore polishing.I mostly agree, but only because stuck oil control rings are the primary reason you can get hard carbon packing in the upper rings and lands.
The oil control rings themselves tend to get stuck with varnish-like carbon that's sticky, but it's not abrasive the way the hard carbon on the upper ring lands can be. So we care about oil control rings not so much because a bit of consumption is annoying (and it is), but also because that consumption can lead to major piston scuffing and secondary failures that are more severe.
Oil ring lands operate a lower temperature and have significantly more cooling flow (scraping residual oil). By contrast, the lands above them get very little oil and rely heavily on thin film lubrication while operating hotter.
The more severe issue is top land carboning and bore polishing/scuffing. That doesn't just cause oil consumption, it takes out engines.
It's all but impossible to have a pristine top land if the oil control rings aren't also doing their job, because the excess oil residue working its way up the ring pack is a contributor to top land carbon.
So when I see a piston with pristine top lands and more deposits as you go down the piston, it tells me that the deposits on the lower portion are inconsequential regardless of cosmetic appearance and that the primary mission is accomplished.
https://bobistheoilguy.com/forums/threads/john-deere-4450-7-6l-overhaul-pictures.369040/
