That’s not true. No mental gymnastics required. Valvoline Restore and Protect has completely cleaned up Subaru engines and resolved oil burning for people here.but that the only data point we have right now says HPL did a fine job.
Bought early October … In Pentastar now …Is this a new label?
So looks like some are seeking clarification - what did you run for 80k - with what observations ?That’s all I ran from new to 80k in an 18 rogue. I’ve used HPL, schaeffers and now hpl and my engine is absolutely pristine. Not a spec of carbon in the filter after using hpl. Of course I never went past 5k regardless of what oil I used.
He said Maxlife 0W-20:So looks like some are seeking clarification - what did you run for 80k - with what observations ?
That’s should have read HPS then schaeffers and now hpl. Maxlife 0-20 was solely used for the 1st 80k.
I don't think they are many people on here that drive 5,000 miles with conventional or synth. blend oils that would make their engines to accumulate sludge and varnish.Some deposits are not going to be removed through chemical means.
You want a clean engine? Start with a clean one, not a dirty one.
Not everything can be remediated.
I leased an 18 rogue back in 18 and the lease ran out during Covid. The buyout was $15k and given used car prices I was crazy not to purchase it. I stumbled into meijer store right before the 1st oil change and they had maxlife synthetic for $1.98 a quart, I bought all they had. That got me to 80k. Like a dummy I stripped the pcv valve and switched out the valve cover at 75k. The engine looked like it had rolled off the assembly line. I used Mobil 1 for 5k, then Royal purple Hps for a couple, schaeffers for a couple and now hpl, all 0-20. I’ve got 6k on the hpl which is the longest I’ve ran any oil in this engine. I’ll change it when I catch a warm spot in the weather. I’m sure I can run this oil for twice that but have no desire to try to.So looks like some are seeking clarification - what did you run for 80k - with what observations ?
You haven’t seen any piston photos though from disassembled Valvoline Restore and Protect/Subaru trials. That’s all I’m saying. There’s no way that a piston needs to be 100% spotless to stop oil burning, and there’s no proof that on the ones that did stop using oil that their pistons are 100% spotless.That’s not true. No mental gymnastics required. Valvoline Restore and Protect has completely cleaned up Subaru engines and resolved oil burning for people here.
I still think it's a winner from Valvoline, at a great price point. Regarding piston cleanliness, they'll never be perfect! They live in a very hostile environment, any oil that can clean them up and keep them clean is beneficial, especially in DI engines.When Valvoline Restore and Protect was first announced and I read the wording (breakthrough, best oil they ever made since they invented it, revolutionary etc.) I was skeptical. But they really did their homework and have all the data to back it up as Dr. England has said when LSJ visited their lab.
Had LSJ not gone there, I'd still believe in the product, but the lab visits really showed how thorough these guys are.
Not only do they have all the lab/engine data, but it's also proven itself in engines through the reduction of oil consumption and hundreds of thousands of miles in actual engines.
“Exceeds” is the key word. Warholic was quick to point out that these types of tests are merely the baseline within the oil market, not the high bar that oil manufacturers should seek to leap over.
"Real-world testing is crucial. For instance, a Ford Mustang was subjected to extensive testing with Restore and Protect, showing significant reductions in wear and deposit formation. The testing extended to various engine components, including the timing chain cover, oil pan, and valvetrain, demonstrating the comprehensive benefits of the oil. The team also ran Restore and Protect in a Ford Explorer with more than 500,000 miles."
“And we also did a chassis dynamometer test where we put a vehicle on rollers basically and ran it 300,000 miles,” Warholic says. “Restore and Protect actually cleaned up the entire engine.”
https://www.enginebuildermag.com/2024/06/dealing-with-deposits-to-boost-engine-life/
On BITOG it all depends on WHO produces the marketing material. If you are a fan, doesn't seem to matter if from your winner.Marketing images are soaked in deception. The Valvoline Restore and Protect marketing images show the cleaning of wet sludge, not dry sludge. Those pistons didn't endure a couple thousand cold starts across a dozen icy North Dakota winters or idle in traffic in the scorching Arizona summers. Every factor behind those piston images was carefully controlled with a formula designed to produce a dirty piston very quickly and Valvoline Restore and Protect to clean it right afterward.
Now, I'm not saying the images are false. I'm also not saying Valvoline Restore and Protect can't remove hardened coking because it certainly can as some results have shown. I'm simply saying that a Brand's marketing carries no weight with me whatsoever. Every brand is going to make their product out to be the most amazing thing ever bestowed upon this planet because that's how marketing works. It's a multi-billion dollar industry for a reason. They play a game of psychological warfare by exploiting people's gullibility, ignorance, and vulnerability to convince them to buy a product. It's a bit of a cat and mouse game with the truth, stretching and twisting things enough to get your attention while also keeping claims vague enough to not draw the FTC's attention. Any CYAs end up in the fine print that next to nobody ever reads.
I'm not being critical of Valvoline Restore and Protect, again making that clear. I'm being critical of marketing. Those piston pictures mean zilch to me.
We don't know what Valvoline Restore and Protect can do to this particular engine in 4K. Valvoline Restore and Protect does not claim to be able to take an engine back to a completely deposit free state in 4K, it says it can get an engine back to UP TO 100% clean based on an adapted version of Sequence IIIH in 4 or more consecutive oil changes:Valid point, but it still shows that HPL couldn't do in 50k what Valvoline Restore and Protect can do in 4k. Even if it took Valvoline Restore and Protect 20k (4x 5k OCIs), it takes them back to fully clean.
Indeed, these types of coatings are the most effective I've seen yet. I'm using Surface Shield.Fluid film and other soft type self healing undercoating has allowed our vehicles to survive more than 8-10 years here. It pays for itself and then some. This needs to become common knowledge to the automotive world. Our roads have so much salt that you really cant make out the white paint lines in winter when the roads dry. Add in dirt roads, salt brine being applied to dusty dirt roads to keep dust down, and you're up against year round corrosion. The salt does not even leave undercarriage cavities in vehicles in the summer months.
There are threads where people who used Valvoline Restore and Protect on Subarus have torn the engines down and taken pics of the pistons? If not, you can’t claim it “completely cleaned up” those engines, just that it reduced/eliminated the oil burning, which almost certainly does not require spotless pistons to do so.That’s not true. No mental gymnastics required. Valvoline Restore and Protect has completely cleaned up Subaru engines and resolved oil burning for people here.
Yes that's true. No piston photos I'm aware of. Just elimination of oil burning.There are threads where people who used Valvoline Restore and Protect on Subarus have torn the engines down and taken pics of the pistons? If not, you can’t claim it “completely cleaned up” those engines, just that it reduced/eliminated the oil burning, which almost certainly does not require spotless pistons to do so.
Quite happy with surface shield as well. Next coat on this subaru will be surface shieldIndeed, these types of coatings are the most effective I've seen yet. I'm using Surface Shield.
