BMW B58 Engine Oil Recommendation
Maybe BMW did not like that Specific LL01FE was basically a regular LL-01 oil with 0.1 less HTHS. The add pack is also not LSPI friendly. The new Motul LL01FE is thinner like all the rest.
The specifications of approval are 3-3.49cP. There is nothing to like or not like if oil meets that specification. LL01 and LL01FE are not LSPI rated. Both approvals do not have LSPI requirements. Specific LL01FE is available only from 2020, so we are not talking old oil blend.
We don't know what goes on behind the scenes. However, I simply think Motul is discontinuing and BMW knows before we do. That additive package will not pass SN+ or SP with that amount of calcium and Motul seems to be moving everything. Even though BMW has almost no LSPI issues I wouldn't run an oil with 3800 ppm of calcium in a B58 or S58. BMW doesn't have an LSPI test but in both US and and Europe from what I see of VOA/used oil analysis on various forums the oils the dealers are now filling are calcium+magnesium SP style additive packages.
Could be. I mentioned that above. However, the replacement product should be then approved before taking it down, which is the case with X-Cess GEN2 API SP. Also, this is specific product aimed strictly at BMW> Now, it could be that Motul is moving everything to one product. They did drop a number of "Specific" products. But do not forget that Castrol, for example, is not planning to discontinue 0W30. Actually, they updated the wording that it is suitable for LL01FE, and it is API SL oil.
Calcium is not an issue if balanced with other additives.
Regardless, I would still go Castrol 0W30.
This replaced the Specific for me last week when I searched S55. It’s an SP LL01FE. A bit lower HTHS like the BMW TPT.
https://new.motul.com/en-US/products/17250?product=MOTUL+8100+ECO-NERGY+0W-30
I agree the Castrol is better but since it’s just a recommendation I’d just go with the Mobil 1 0w-40 now anyway. I wish the Castrol had a more modern additive pack with that nice base oil.
cant have it all! i wish we had that castrol 0-30 in europe! our castrol 0-30 is not that stout! as we still dont have Mobil 1 0w40 sp yet also!
If you want a non-dealer branded oil there's Mobil 1 ESP 5w30 or Shell Euro L 5w30 which are both LL04 and are available at retail stores. If I did my own oil changes I would use one of these simply because it's comparatively cheap and I'm changing oil on time (1yr) rather than miles.
Redline is a good street oil for track use.
what if you do more miles before that 1 year OCI ,3000miles more for example ,will you still change it in a year?
The safe bet is probably sticking with the dealer branded oil and changing it on a strict 5K/6 month schedule?
if that is 5000miles/6 month ,yes that's what i do too.
I've used the HPL Euro 5w30 but because I'm not driving as much as I used to I transitioned to Indy shop bulk 5w40 (Liqui Moly). For my own application (435i) I don't feel I'm getting my monies worth based on the low miles. I could go longer but I'm not in the mood to deal with any "You missed an oil change" BS from prospective buyers who pulled a Carfax.
Dealer (Castrol) oil is going to be fine. I don't know why BMW owners sometimes knock it. It holds viscosity really well.
which LM 5-40? bmw -shell europe is a fine oil, i use it right now. dont know about bmw castrol.
from new year its gonna be castrol bmw here too,so i am thinking of it .but i guess bcs. its not the same castrol they use in US.
I put around 6k miles on the HPL fill last year. The interval in the US is the lesser of 10k miles or 1 year so I would go by that regardless. In any case I can't change my oil at home anyways so it's somewhat moot.
Castrol has LL01 approval and recommendation for LL01 FE.
Also, that new Motul is not on the list.
I generally don’t pay attention on those lists. BMW is confusing with oil recommendations almost (almost!) as VW.
Yes, for those that care about FE, technically Castrol doesn't have FE with just a recommendation. Not that anyone should care, but you know how it is.
The list is probably not comprehensive or someone missed something. BMW probably has an intern making those lists :D.
This is what I meant. Though, I always find astonishing that although approved, they put: exceed.
Shell Helix Ultra 5W-40?
i am not searching for oils , i know the good ones that are sold in europe. but yeah ok, very good oil, i like shell oils both 5-30 and 5-40. bmw tpt which is shell 5-30 but custom made fro bmw ,as i was told,is in my engine now . no complaints.
i was more referring to these 2 that are considered the most talked oils right now here in bitog. Mobil 1 0w40 will come to europe in time, but i was really interested to try this US 0-30 bcs. among other things it suits with my commute too.but this US version is not coming .
Is there any reason to not use mid/low SAPS oil in the Bx8 family?
LL-01 seems better if you're tuned and are concerned about fuel dilution or something, but otherwise I'd think LL-04 is the way to go in any case.
Castrol 0w30 seems like a better option if you're in the E90/pre-LCI F30 era.
In what region? The reason to use LL01 is warranty in North America and certain parts of the world if you don’t have GPF. Otherwise, use LL04.
why ll-01 is better for fuel dilution?
i know, i asked him if he has a different knowledge.
It has a stronger additive pack and can retain enough additives longer. However, that is not per se issue if ULSG is used. It could under certain circumstances make difference (a lot of short trips, stop and go), but generally it is non issue in the US since 2017.
