f355spider
$50 Site Donor 2026
Crap, I have the BMW oil recommendations from 2020, but don't have it in a format this website likes...
you linked to a file on your hard drive, or incorrectly used the share link in OneDrive
Yup, I am aware. Tried deleting that post right after, no luck at the time.you linked to a file on your hard drive, or incorrectly used the share link in OneDrive
people can search this pdf filenameYup, I am aware. Tried deleting that post right after, no luck at the time.
I've posted it on other sites without issue, not sure why I am having formatting issues here. I am going to print, scan and try posting that way in a moment.people can search this pdf filename
3.0 Technically appropriate engine oils for BMW Group engines.pdf
and there are several BMW forums where the file can be downloaded. i would link it, but i don't know bitog's policy on linking to other forums
The hard part is finding anything newer than 2020 because BMW shutdown newtis.com and those who do have access are stuck with information which is current at the time. Still a great resource for older models.people can search this pdf filename
LL01 in almost as many as well. Usually as an alternate with a fuel economy disclaimer/warning, same as LL04.In reality you can use a Longlife-04 oil in nearly every gasoline BMW ever made except for the M models.
if you have the full version of adobe acrobat standard, you can save the pdf pages of a file as jpgsI've posted it on other sites without issue, not sure why I am having formatting issues here. I am going to print, scan and try posting that way in a moment.
update: no go....for whatever reason I'm unable to get this formatted in a way the site will accept it.
there are some new changes at the specs of motul x clean+ 5w30:That engine is designed around heavy W30 and lighter 40 grades. But, you could pretty much run anything in it. There is no such thing as overkill.
Take into consideration that when you say "grade" that is KV at 100c. Your BMW in regular driving is running around 109-113c. That means that at regular driving, your oil is bit thinner than you think. That is why HTHS is important and not grade per se. There are different oils, some meeting minimum requirements, some exceeding it. Generally, oils with lower KV100 but really good HTHS are top of the line oils. Motul Gen2, Castrol 0W40, Castrol Edge 0W30, Pennzoil 5W40, etc. are all superb choices. Motul X-Clean+ 5W30 would be prime example of superb oil, as it has KV100 of 11.6 and HTHS of 3.6 and it is LL04. Valvoline European Vehicle is at 13.1 KV100 and HTHS 3.7, which is really good.
Again I would go with approved oils for LL01 and LL04, regardless of weight.
If you decide to track vehicle, than we are getting into different conversation.
They have new X-Clean+ 0W30 EFE that has pour point-51.there are some new changes at the specs of motul x clean+ 5w30:
VI 100 c is 11.8
hths is 3.5
flash point 226
pour point -36
noack 10% from what i remembered in another topic
https://azupim01.motul.com/media/motulData/DO/base/8100_x-clean__5w30_en_fr_motul_17720_20230214.pdf
is it still considered a superb oil?or 3.5 hths makes it not superb anymore?
bcs. there are a lot oils with almost same specs like this one:
https://msdspds.castrol.com/bpglis/...C5DBEA980258A0500375AF2/$File/wepp-cuj924.pdf
ok hths is not mentioned but min. would be 3.5 like motul's
or some shell,fuchs,LM, 5w30 oils most of them hths would be minimum with 3.5,so
what exactly makes this motul a superb oil? by the way bcs on writting we can not express the way we mean sthing, i am not sarcastic,i am curious ..i have used it once and found it good,but why superb in compare the others you mention or i mentioned?
yeh, i saw the used oil analysis.. motul x clean efe 0-30, i mention it to you at spring, remember ?They have new that has pour point-51.
That one 5W30 I used in Atlas and returned excellent used oil analysis.
I have now mix of ESP SN and SP. But I have new EFE on shelf. It is still hard to find. They just got it into distribution.yeh, i saw the used oil analysis.. motul x clean efe 0-30, i mention it to you at spring, remember ?
but i cant find it anywhere near me.
do you have now the new mobil sp 5-30 in atlas and tiguan? is so then i am sure you will post a used oil analysis in time. maybe the first one of new SP.
2024 X5 40i in the US come with B58TU2 engines, and more specifically, B58N for short and B58B30M2. Here is the most reason technically suitable oil matrix:I have a new LCI X5 40i with the TU2 engine. The oil sticker under the hood says to use 0W12 and the manual says to follow that. I'm trying to stay away from 0W12 and at a minimum, I'd use a 0W20 but the owner's manual on page 368 has no mention of 0W20 as a suitable oil. Now the 2024 X6 40i owner's manual on page 359 says 0W20 is a suitable oil. I would assume the 24 X6 uses the TU2 engine also. Any idea why the a difference?
As you can see, if your car doesn't have a GPF (gasoline particulate filter) (identified via optional equipment code SA1DEA RDE exhaust emissions standard), then you can use LL01FE, LL12FE (if in EU), LL17FE, and LL22FE.
If your car comes with a GPF, then you can't use LL01FE.
why a mix? you had no more SN and wanted a fill up?I have now mix of ESP SN and SP. But I have new EFE on shelf. It is still hard to find. They just got it into distribution.
Had leftovers.why a mix? you had no more SN and wanted a fill up?
