Yes i compared the maximum torque of the non disa e36 2.5 i6 against the n52 2.5 i6 with disa and if i am not mistaken the n52s maximum torque was already around 2500 3000 rpm and the non disa engine was around 4500 rpm.
My electric waterpump is the original one and is now at 224k miles, i think i will change it before it fails after 15 year. But yes its expensive.
I had the radiator fail at 190k, the plastic side cover that is clamped to the alluminium leaked inbetween.
The o ring in the plastic pipe mounted on the front of the cylinder head becomes hard and also seeped a little. I have replaced this at 210k.
Due to the variable heat management the ECU will give warning when its over 120 celcius, this is way too hot. The reason why its so high is that the engine is allowed to run at 110 celcius due to ECO mode when the ECU notices youre cruising at low load at a constant speed. Due to the length of the ALU cylhead its more sensitive to deforming.
When people do not stop immediatly when they get a warning they will ruin the engine. There is no time to drive to the next exit.
I would open the bonnet and put the car on accesory mode, then the electric fan should keep turning due to to high engine temp.
QUOTE mightymousetech: Will disagree with that. The N52 is a tank of a motor, very stout. Also makes significantly more power, and thanks to valvetronic, is significantly cleaner and better FE. Everything a motor is supposed to do, it does it better. Plus, I hate working on those old MXX motors. LOL
Yes i agree, when you compare the N52 to its competitors at that time it had the highest ouput per liter for an n/a 6 cyl engine.
Too bad they couldnt/didnt make them after that, would love to see 100hp per liter n/a inline 6es.
