5w30 in a car spec for 0w16
thick vs thin is pure nonsense, the real issue is fluid film protecting vital surfaces, and yes i remember a kid with a honda or Acura with cam phasers having a code read because his buddies had said to put Rotella diesel oil in the sump. do you realize, that thousands of hours and miles oftesting are run before product launch
Viscosity is the first line of defense against metal-to-metal contact between moving parts. There is a difference between film thickness (MOFT) and film strength.
Would Castrol Magnatec oil play a significant role here?
In terms of what? Film strength is dependent on the AW/AF additives and how they prevent wear when parts rub on each other. Film thickness is dependent on viscosity, particularly HTHS viscosity, and is what keeps moving parts separated and from rubbing on each other.
You would be a CAFE appeaser too if you were facing heavy fines if not complying.
Not sure if CAFE "fines" per se, just doesn't give credits which saves the company money ... so guess it could be looked at as an "indirect fine".
Okay.
But, Castrol "CLAIMS" that "X amount" of engine wear occurs at startup. Are the additives and viscosity you stated ever present at startup? Isn't this why Castrol Magnatec was invented? Or, is it a highly fictional ploy on their behalf?
I'm still trying to see that force field it gives off around engines. :rolleyes:
Okay.
polar sticky molecules is just marketing
Okay.
Theoretically, if a thicker layer of oil stays clinging to surfaces after the engine is shut down, then there should be a bit more protection during a start-up. Start-up wear would also depends somewhat on what kind of AW/AF layer has been built-up on the surfaces (the film strength of the oil) to help mitigate wear when there is more rubbing contact before full lubrication is established.
If you have a stash of 5w30 I would use it without hesitation, if you don't then buy some 0w16 or 0w20 until the warranty runs out.
I'm using 5w40 in the camry that specs 0w20 and don't see any difference whatsoever, I also have 10w40 in my stash that I plan on using in the camry and 4runner at some point.
