Yes but you constantly refer to the .05% in fuel savings.The discussion is specifically about the oil pump, not the dozens of other things done with an ICE to save fuel.
Yes, it’s a conspiracy … just drove the Jeep and it does everything the same as my GM …It doesn't matter how they are controlled or if they are very efficient, the main purpose is to cut back oil flow to save fuel. And there are many different designs on how to do it, some more complex than others. The vane pumps are still positive displacement, and aren't 100% efficient either. But if they are more efficient because of less internal mechanical rubbing friction then that would help on top of less hydraulic pumping loss (due to decreasing output flow) in the overall decrease in parasitic HP.
If you think these pumps weren't invented to save pumping HP loss and save fuel, then exactly what was the main purpose in your mind?
I haven't "mis-quoted" the reasons they were invented, go read up why and it always points to saving a minisule amount of fuel to try and meet CAFE goals. Post up articles that show the reason is completely otherwise.
Well, to your point folks come on here often to say my old truck got 15 mpg … but this one, wow … it more than adds up … it compounds ~You are concentrating on the oil pump. The car designer/engineer is looking at the mechanics as a bigger picture. A little here, a little there, adds up to what their goals are.
Constantly? ... think it was mentioned twice to get the point across that it's not much based on the reduction of the hydraulic pumping losses. The focus is variable volume oil pumps, nothing else associated with ICE efficiency. What's your point?Yes but you constantly refer to the .05% in fuel savings.
Fact remains that I haven't "mis-quoted" anything as you claimed about why variable volume oil pumps were invented, regardless of what you think the "other benifits" are. Post up one article that says their main goal isn't to reduce parasitic HP loss and increase fuel economy by a small fraction by cutting back oil flow. That's exactly what I've said, yet people want to twist things up and go off focus for whatever reason, lol. Just don't want to agree? ... or you don't believe that's why they were invented? If the latter, then exactly why do you think they were invented if it wasn't to save fuel? Haven't seen any links that say otherwise.Yes, it’s a conspiracy … just drove the Jeep and it does everything the same as my GM …
You have claimed less flow at both low and high RPM’s … In fact the ECM looks at a data set and decides what it needs and adjusts rapidly …
As for reasons … have already stated some besides MPG …
Surely you remember the stuff going around on the increased PSI PF63E and all that … the memos made reference to “high flow lubrication requirements” … Why did they need that increase for 0W20 engines that run hotter than ever …Fact remains that I haven't "mis-quoted" anything as you claimed about why variable volume oil pumps were invented, regardless of what you think the "other benifits" are. Post up one article that says their main goal isn't to reduce parasitic HP loss and increase fuel economy by a small fraction by cutting back oil flow. That's exactly what I've said, yet people want to twist things up and go off focus for whatever reason, lol. Just don't want to agree? ... or you don't believe that's why they were invented? If the latter, then exactly why do you think they were invented if it wasn't to save fuel? Haven't seen any links that say otherwise.
The GM TSB (not "memo") was because of the location of the oil pressure sensor and the possible surge of oil volume at a cold start-up that could happen (and cause the oil filter to bypass crud with thick cold oil, even with 0W-20) before the variable pump output volume could become controlled. I think you're misunderstanding the big picture on that one. Doesn't mean the engine needs more oil flow because the engine is "starved" or needs/has more oil flow because it uses 0W-20 oil. A regular old PD pump could do a fine job too, but at the cost of maybe a hair of lost fuel economy but with less complexity.Surely you remember the stuff going around on the increased PSI PF63E and all that … the memos made reference to “high flow lubrication requirements” … Why did they need that increase for 0W20 engines that run hotter than ever …
For these oil deprived motors ? Sure didn’t matter on all the old gens I owned and serviced …
Yes, I have a single point of view/focus, and your claim that I've "mis-spoken" about why variable oil pumps exist is false. Every write-up about them says what I've said why they exist, so you might as well just call me a liar because that's how it came across when I read that comment, even though every article written (including SAE articles) say the main reason VVOPs exist is to save fuel. That's the focus, and the variable volume oil pump wasn't invented for any other reasons, regardless of how you might think it pertains to your specific engine. The bottom line is they are to help save a miniscule amount of fuel. Good that they work, but like I said more complicated than they're worth IMO, and could care less if anyone agrees or not.Sorry you want to drag everything thing back to your single point of view … but these are complicated GDI engines with VVT … AFM … and ECM controlled pressure and oil cooling features … They produce volume/pressure on demand … less when not needed … and a surge of volume/pressure when needed …
have around 350k total on vehicles with these … no lube system issues … none used oil …
Probably best at this point since you can't show any proof that VVOPs weren't invented to save fuel and instead for some other reasons. Agree to disagree as it's just going in circles now.I‘m done here …
Those are 3.0 and 3.6 liter V6 engines. The TSB I was talking about was for V8 engines where the oil filter bypass valve setting increased for the ressons I stated above.Just to get some context here, is this the TSB?
https://static.nhtsa.gov/odi/tsbs/2020/MC-10181678-9999.pdf
The VVOP is so innovative that it's not even mentioned among the many things that are used to gain fuel economy.The fuel economy gains from the newer oil pump might be minuscule but if added together with other innovations and new efficiencies the numbers might make sense.
US Department of Energy paper (PDF).
https://www.energy.gov/sites/default/files/2015/11/f27/QTR2015-8C-Internal-Combustion-Engines.pdf
https://www.consumerreports.org/fuel-economy-efficiency/fuel-saving-innovations/
https://www.consumerreports.org/fuel-economy-efficiency/new-ways-carmakers-are-getting-you-more-mpg/
Yeah, I'm sure they know nothing about ICE fuel efficiency technology.Well, that’s the government for ya.
My Lexus UX 250h has great balance. The AWD. The eCVT. The little electric motor at the rear axle.The fuel economy gains from the newer oil pump might be minuscule but if added together with other innovations and new efficiencies the numbers might make sense.
They did - there was a TSB for that. Honda also did something similar.I thought I read somewhere that Toyota back specked 0w-20 /5w-20
Still regular until it moves to the Mazda-derived Dynamic Force engines. Probably with the 5th gen model but with CARB/OTC states as well as China going all in with xEVs, that’s to be seen.What kind of oil pump does the Prius have? Is it variable, or regular?
Thank you.They did - there was a TSB for that. Honda also did something similar.
FWIW, the reason why Toyotas of the last decade or two tend to burn oil might be more design related than oil related. The oil burning the Camry/Corolla/Prius and some of their V6 models is documented on the ‘net. It’s a combination of not enough oil return holes in the pistons and low-tension rings - more so the former getting clogged. Toyota engines tend to run a little hot and hard on oil. Even with OCD, a Prius in the family started to drink oil. A piston soak greatly improved but didn’t completely eradicate the problem.I don't want any oil burning issues like other owners have had.
