2002 Ford Expedition 5.4L 12,000Km M1 TDT 5w40
OVERKILL
$100 Site Donor 2021
Ontario, Canada
Here is the UOA from my Expedition. Mileage on unit: 174,000Km Mileage on oil: 12,000Km Filter used: Fleetguard LF16002 Oil used: Mobil 1 TDT CI-4+ 5w40 Apparently, they didn't test for TBN or TAN. I'm going to have them re-run it, because that was the entire purpose of this!!!
Everson WA - Pacific NW USA
Another good run om M1 5W-40 TDT. Your wear metals look delicious. The lab also forgot to convert units traveled from Canadian to American. (7500 miles give or take a flatten beaver, eh?)
OVERKILL
Ontario, Canada
BAH HAHAHAH, it's a Canadian Lab eh ;\) Though I imagine the fact that it doesn't state Km is going to screw people who don't read what's posted above the UOA up.
Texas
Man you are lucky! You know that thick stuff is NO good for our mod motors. Please don't do that again.
Illinois
Looks good. Did you cut open the filter this time? Any grit like last OC? What oil did you decide on for your next OC?
Canada
You have to ask for a TBN on their tests, and they will do it. I don't like the way the don't test Calcium or Boron - I don't understand why not those two. But, at $18 a test vs. $30+ for others, I'm not going to complain! Results look good, but Zinc seems low for a CI+ HDEO? Oil held viscosity well.
OVERKILL
Ontario, Canada
Filter was posted in the oil filter section a while back when I changed the oil. Titled Fleetguard LF16002 IIRC. More junk in the media for sure.
OVERKILL
Ontario, Canada
I should note that the bottle the oil was put in had been fresh through the dishwasher and had some "junk" from the dishwasher in it at the bottom. I wiped it out the best I could but I have no idea what chemicals dishwasher detergent has in it. Doesn't seem to have affected it though. Dog ate the original UOA container when we left him at home.
OVERKILL
Ontario, Canada
Uh oh, it has a fresh sump of it in it again! ;\) Will be getting another UOA for sure. I'm trying to see how long I can run this stuff for.
OVERKILL
Ontario, Canada
1. I have e-mailed them back asking for TBN. 2. Yes, for the price, I couldn't beat it. 3. I'm wondering if this is because the engine USED some of the Zinc? This OCI had me towing ~4,000+lbs 500Km, then 3,500Km of some VERY hilly terrain with the vehicle loaded to the gills with people and luggage. I know it is a sacrificial additive, so that logic makes sense to me......
Iowa
Hey Overkill, do you think I can run this oil in my Corolla for an oci or two? Just want to give it a try, maybe some extra cleaning can be done. Thanks, nice report btw.
OVERKILL
Ontario, Canada
Just got a reply. They have already disposed of the sample, but have indicated to me what I need to do in order to get TBN on future samples. So there won't be a TBN for this one unfortunately \:\( panthermike: I don't see an issue with it. Is the engine spec'd for 5w30? If so, going up a grade isn't going to be an issue.
Canada
Honestly, you'll be able to get 30k km out of it easily. 12k km is a bit of a waste - I would have gone at least 16k km (10k miles)....but you're working on it.....
Iowa
Yes, it specs 5w30/10w30. Just making sure it's good for the cats, is it for the newer diesels?
OVERKILL
Ontario, Canada
Unless you are burning lots of oil, it doesn't matter really. It is also gasoline engine approved.
OVERKILL
Ontario, Canada
Yes, Doug had suspected I could get somewhere in the neighbourhood of 20K out of it. But had suggested I change it and check. Looks like I can't do that now, since no TBN for this sample. So I will run the next one to 12, and get TBN done then.
Iowa
Hmmm, maybe I shouldn't then. The Corolla burns about a quart every 1500 miles.
OVERKILL
Ontario, Canada
Maybe try it once then? I say that because mine was going through 1L every 8,000Km on the 5w20, but went through nothing on the TDT.
Iowa
Oh, I see. Maybe I'll give it a shot then, thanks for the info!
