M1 0W40 FS (updated formula) vs PPE 5W40 (API SP)
Which one is likely to be easier on the cats?
M1 SN
M1 SP
PPE
I am running PPE and noticed a lot of soot coming out of the tailpipe after 5K
M1 SN
M1 SP
PPE
Unless it is a 2 stroke I wouldn't worry about it. Unless the engine is burning a lot of oil you have a fuel issue not an oil issue, I see a lot of Euro cars with cats 20 years old and older that have used higher zinc/phosphorous oils their whole life that are well maintained and the cats are still fully functional.
The engine running rich can overheat the cat and destroy it regardless of the oil used. Running leaded fuel which is not applicable today would wipe a cat out in a few thousand miles if that.
Thank you. Actually it did start consuming oil a short time before I noticed the soot on the garage floor behind the tail pipes.
ah, a bavarian here in bitog! can you please define a lot of oil? have some issues too.
The one time I saw an O2 sensor generating an efficiency code due to oil burning the car was using something in excess of 1 quart per 500 miles.
do you remember the code.? i have reasons..when i replaced the injectors ,as always there is an o2 sensor error, probably of bsc, injectors failing . i replaced them on dealership with a good will second time the same way.anyway the dealerhip mecahnic wanted me to take me a ride. wanted to replace the sensor. and lambda.i told him that i will go a long ride and the error light will turn off.just like the first time.and it did as i expected. but..
i have 400-500ml consumption per 600 miles. is it considered oil burning ?
engine coolant temperature sensor (ECT) issue can flood the engine with gasoline and thinn out engine oil, also will mess with O2 sensor
Generally, 13.5 gives HTHS around 3.7-3.9. Motul X-Cess I have in BMW now has KV100 of 13.5 and HTHS of 3.8.
Castrol Edge 0W40 has KV100 13.1 and HTHS of 3.7.
Of 0W40, I would go with Castrol 0W40, although my favorite is still Castrol Edge 0W30.
Of 5W40 oils? Motul or Pennzoil. Pennzoil is 13.1 and HTHS is around 3.88.
I used Mobil1 0W40 extensively, but this HTHS is really poor.
I was looking around PDS on Castrol’s website and I saw that the latest API SP 5w40 a3 version had a higher KV100 of 13.5. Would that put Castrol in the 5w40 conversation?
I did not see new API SP version and just checked now. I mean, it looks like any other Group III. I would still go Motul or Pennzoil if 5W40 is a must.
Knowing Catsrol it is step below 0W30/40.
