Shut your mouth. Don't ever let facts get in the way of a good rant.Thought the first Mobil 1, invented back in the 1970s, was a 5W20?
Yeah that's group 1 base oils. You can't really even get PCMO made from group 1 base oils in North America anymore.I'm unfortunately old enough to remember what rubbery 10W40 VIIs did to the inside of oil pans... And tops of cylinder heads... And everywhere! Talk about clogging up stuff!
Even the retro SG, SH, SJ rated oils are all made from at least group 2.
Group 1 oils were the ones you had to change around 3,000 miles and you were living dangerously changing at 5,000.
I think that's the reason. I have seen it. I posted a thread not long ago about recently using sj rated Pennzoil from around 1998. It has wax bugers in it. That oil ran fine in my lawnmower.Is the Grp 1 issue the cause of the Pennzoil "wax in oil" thing or is that a totally different issue?
No it was the inferior VM of the time. Other less wide-spread grades did not have the same problem.I think that's the reason. I have seen it. I posted a thread not long ago about recently using sj rated Pennzoil from around 1998. It has wax bugers in it. That oil ran fine in my lawnmower.
Yes fuel economy and long-drain capability.Any idea/thoughts how that was marketed upon release as far as being "better"?
"Our new 5w-20 is 50% lighter than our 10w-40 which means more MPG and less fuel fill ups!" I'm guessing, especially with the beginning of the oil crisis happening...
That could be the case, or maybe it had the HTHS of a 0W-16, depending on the type of VII used.API grade requirements have changed multiple times since then. Although HT/HS hadn't been invented back then this oil was likely near 3.0 and not like today's 20-grades. It was sold as a replacement for existing 10W-40 oils.
Way way back, compared to TX crude, Pennsylvania crude had more wax which would cause varnish if run too long. However it held viscosity better.Is the Grp 1 issue the cause of the Pennzoil "wax in oil" thing or is that a totally different issue?
You’re correctThought the first Mobil 1, invented back in the 1970s, was a 5W20?
It was just a cheap conventional 5w30 oil. The only less wide spread grade available would have been a 10w30. Around that time 0w30 was still kinda new, or if it had been around no one had really heard of it.No it was the inferior VM of the time. Other less wide-spread grades did not have the same problem.
Have you forgotten the member who has a 1957 Plymouth and posted the page from his owner’s manual that showed 20 grade as an oil option?Its the OEMs unholy quest for cafe.
Until the government dreamed up cafe probably during an acid trip virtually no one ran 20 weight oil in vehicles since the advent of multi grade oils.
Interesting, I have NO VII HPL 5w20 in sump.I do not believe there are any 0W20 or 5W20 Euro approved oils by VW, BMW , Porche or MB - correct ? If correct - then why are only 30 and 40 weight oils able to meet Euro oil specs ? Based on potential , likely answers (beyond CAFE) either the USA cares more about gas mileage / fuel economy than Euro vehicle makers or Euro vehicle makers don’t think a 20 weight oil can hold up to maintaining engine life standards they have set forth for their vehicle brands ?
I started using Mobil 1 5w20 in 1978 while living in Maine. The go to oil at that time was 5-40 Valvoline (my oil of choice) but it caused terrible valve clatter in my V8 Chevy in extreme cold temps. Mobil 1 5w20 cured the start up clatter then and I've stayed with it ever since. M1 that is of various wts.Thought the first Mobil 1, invented back in the 1970s, was a 5W20?
I ran 10W40 and 10W30, maybe even some 20W50 in my ‘72 Pinto in the early ‘80s. I don’t really remember seeing much 5W30 until the late ‘80s, but I was too poor back then to have anything new anyway. I didn’t even have an EFI car until my ‘84 AMC/Renault Alliance I had in 1986 or so.Out of curiosity, and since you have possibly dated yourselfwhat was the standard weight of oil that Joe Anybody would be running in their plain as white bread Ford Pinto or the likes back in the mid-70's? 10w30 or 40 I assume?
Found this old thread about 5w30's introduction which also touched on the issues with 10w-40's...
https://bobistheoilguy.com/forums/threads/when-did-5w30-first-come-out.59456/
Not to mention high heat resistance, superior arctic cold flow capability, and cleaning ability. M1 was so far ahead of the pedestrian oils of the time-we don’t realize how much better we have it now. Engines that were once gone by 100K have the ability to still be running strong at 300K!Yes fuel economy and long-drain capability.
Is the 2.6 HTHS of today’s 5W20 oil really that much worse?API grade requirements have changed multiple times since then. Although HT/HS hadn't been invented back then this oil was likely near 3.0 and not like today's 20-grades. It was sold as a replacement for existing 10W-40 oils.
There have been several white papers posted that show HT/HS vs wear has an inflection point right around 2.7 HT/HS IIRC. Meaning, wear begins to accelerate very rapidly below 2.7 if additional engineering measures (wider bearings, tighter clearances with tighter tolerances, variable volume/pressure oil pumps, etc) are not taken to offset the lack of sufficient oil film thickness between contact points in the engine.Is the 2.6 HTHS of today’s 5W20 oil really that much worse?
I never said it wasn't an option. I have said it was regularly used as winter oil until multi grade oils were widely adopted. I'm sure they continued put straight 20 weight in manuals for quite some time even after multi grades were in wide use for old people who were set in their ways.Have you forgotten the member who has a 1957 Plymouth and posted the page from his owner’s manual that showed 20 grade as an oil option?
