Quote:
I think its unfortunate how this manipulation has made '10W-40' a general 'bad thing' in oils. Modern 10W-40's don't do what old ones did, and there are some engines that do better on thicker oils. What I think is funny is one of the engines that seems to do better on thicker oils are GM OHV engines. If you look at UOA's they tend to show somewhat better numbers on this weight. But GM has banned them, this has now stuck with people, so they miss out on the benefits of it....
Quote:
Quote:
The only modern GM OHV engines that do better on '10W-40' are the ones with manufacturing/design defects.
That would be most of them (the 60* V6's).
Quote:
Quote:
That would be most of them (the 60° V6's).
You have any credible evidence?
Quote:
The technical problem was that the light base oils needed to make the 5W-X oils were in tight supply. They quickly and cleverly fixed that by changing the specifications for 5W to allow slightly heavier base oils to be used.
The marketing problem was bigger. Consumers were thoroughly sold for many years that 10W-40 was the ultimate universal grade of oil for all cars, and retailers stocked what consumers bought. So when the oil companies introduced the new 5W-30 oils, they were not well received and not given the retail shelf space needed to be considered "readily available". Even though the new car manuals recommended 5W-30s, they still had to allow 10W-40s, and the manual recommendations just did not have the reach and power to dislodge the entrenched 10W-40 concept from consumer’s minds. The car manufacturers needed to get more creative.
Quote:
Excellent dissertation, however, I recall the struggle to be more between 5w-XX and 10w-XX oils, as opposed to a struggle between 5w-30s and 10w-40s.
Quote:
Quote:
LOL! and I'm sure that GM's headgasket problem has nothing to do with this...
Quote:
One can get some insight by reading letters between the EPA and the manufacturers made public by the EPA here:
http://www.epa.gov/otaq/cert/dearmfr/mfrltrs1.htm#1980
See the Manufacturer Guidance Letters CD-81-02, CD-84-05, CD-84-11, CD-86-15, CD-88-20 for a start.
Quote:
You are correct 427, but they specifically attacked the 10W-40 because it was the most popular oil and commanded the most shelf space at retail. And 5W-30 was the grade they pushed because they knew the public was not ready for a 5W-20 oil - too radical of a change and the M1 5W-20 problems were fresh in their minds.
Tom
Quote:
Quote:
I'm not a mechanic. Is the head gasket and intake gasket the same thing? I've hear of GM's intake problems - but I never seen it worded as "head gasket".
Quote:
I had a 3800V6 with 180,000 miles on it when I donated it to charity. I used mostly 10W-30 in it, but the last fill was 10W-40, and I can tell you I noticed little difference, and if I were forced say which oil seemed to be more agreeable to the engine, I'd definitely say it was the 10W-30. I hate to say something that is really unverifiable such as the engine "ran sluggish" with the 10W-40, but...
I will say that the 10W-40 cut down the oil usage from a whopping .5 a quart in 5000 miles to maybe .33 a quart in 5000 miles, but that may also have been the cool early fall here...
Cheers
