What makes Euro oils different?
If you’re going to stick with 5k intervals then by all means go with ESP. But with AMSOIL Signature Series I think you could be doing 10k and getting your money’s worth that way.
I could easily go 7.5k-10k most likely. I want to see how this next UOA looks after very short trips (<1 mile in 20F weather).
I recently change the Audi from 0-20 508 to the Mobil 1 ESP 5w30 504/507 rating and will keep changing it anywhere from 5-7K miles as I do it myself. I've made this change based on what I read on this forum where it seems, at least to me, a consensus that its a better oil for my purposes which is to get as long a life as I can out of the Audi.
Good move.
European regulations are targeting really really extended oil change intervals. I don’t know how they keep cars running with such crazy intervals. Maybe they want to support the mechanics union and auto manufacturers. 15km, 20km, 30km intervals. Just absolutely bonkers.
I'm not doubting you ... I've heard and read the same thing. Can you, or anyone, provide some instances of these long OCIs?
EU tried yo push these 20k miles OCI. But only certain markets, mostly Germany, Netherlands etc. where gasoline is laboratory clean, roads don’t have dust etc. In most countries they kept 10k miles or 16kkm intervals.
Another thing, vehicle in European culture is bigger investment than in the US. People in general are more aware of servicing needs etc. So, even though manufacturers might recommend longer OCI, generally 10-15kkm is standardized OCI.
Don't they have some laws in Germany making it either impossible or very expensive to keep a car past certain age and expensive to dispose of at scrap yards? Like 7-10 years or so? And Poland becomes the place of car disposal?
Local area Advance Auto stores carried Total Quartz brand European oil in a couple of different weights including 5w 40 and 10w 60 a couple of years ago in 5 liter jugs and 1 liter bottles. No one was buying it (it was pricey). They ended up clearing it out for really low prices.
When I check the maintenance minder on my M3 it shows the # of miles remaining and the approximate date of the next service. This is what it shows when reset after an oil change.
Just shy of 25,000 km.
They have very strict technical inspections. All European countries do. Some have central video data system where all technical inspections necessary for renewing registration are stored.
Yep. ESP is exactly the same price as regular Mobil 1. And a bit cheaper than some of the other synthetics at Walmart.
But other Euro oils such as Quaker State Euro are cheaper, I’ll give you that.
I was going to say.....I'm pretty sure the ESP I bought at Walmart was the same price as every other Mobil 1 oil there...
Euro oils have higher TBN. API SP alone normally has 6 to *+ TBN,
No.
ACEA A sequence is full SAPS.
ACEA C sequence is mid-low SAPS.
There are Euro oils with TBN below 6. Ester based ESP version from 10yrs ago had TBN at 5.8.
Whoopsy blunder by me, coz I only ever use ACEA A3/B4 oils.
No.
And I’m not too worried about TBN either. That’s pretty far down on the list of what I care about in an oil. Low sulfur gasoline has rendered it far less important unless you’ve got an engine with issues.
Agreed! Plus one of the things I have learned in all of my years on here is that the starting TBN isn’t as important as its retention over the OCI. Better to have an oil that starts with a TBN of 6 and finishes with a 5, than one that starts at 10 but finishes at 2.
tell me about it! ever since i moved to south europe the quality of gas is zero,garbage..what i have learned ,the hard way here, is that many E90 bmw's ,DI ,their injectors which have a bad part and its known ,in germany last wayyy longer than in south europe.why? the worst gasoline in europe. its worst if you have a car just for in-town. the fuel system needs your mechanic every month.
Agreed! Plus one of the things I have learned in all of my years on here is that the TBN number isn’t as important as its retention over the OCI. Better to have an oil that starts with a TBN of 6 and finishes with a 5, than one that starts at 10 but finishes at 2.
exactly! but we dont know that unless we use it.there are indicators of full synthesis of oil but they are just speculations.
