I wonder if they'll do a thicker version of it. Say a 5w-40 or a 0w-40 for in Europe. I'd love to use it in my HDi Peugeot engine. Is it only designed for petrol? Or do you think it'd work on a non-dpf diesel engine?
It is not diesel compatible at all currently.I wonder if they'll do a thicker version of it. Say a 5w-40 or a 0w-40 for in Europe. I'd love to use it in my HDi Peugeot engine. Is it only designed for petrol? Or do you think it'd work on a non-dpf diesel engine?
Right now its not even sold in Europe, so guess we will find out later.
Also lacks ACEA spec and cert/approvals for diesel engines, as far as I can tell atleast.
Because both vehicles like to eat 0w20 for breakfast. Much of OCI will run through the summer months too. So I prefer a 30 or even 40 weight.You could go for 0W-20 in the winter time. The 20 grade in cold AK weather would probably be fine since oil temps will be down.
What is ur OCI and previous oil used?Did a valve adjustment and gaskets/plug seals on my 04 TL. There was some heavy varnish on the front valvetrain, dirty PCV side. It's been about 1k mi since and I'm seeing very similar results to @Fa24wrx . The fasteners were previously all deep honey colored or brown, but I'm beginning to see bright silver zinc. The oil that pools in the recess on the hex heads has suspended grime that has been cleaned from the metal. Springs, rockers, casting, and dipstick are all brightening/cleaning up also.
Can definitely tell it's less varnish! Impressive for 1k miles
2nd owner here. Previous owner was a family friend and did all dealer service for 127kWhat is ur OCI and previous oil used?
Here's one with some more rocker and the plug tube.Can definitely tell it's less varnish! Impressive for 1k miles
That’s a great price! I paid just under $30 at Walmart and I noticed on their website that it is listed as $26.60 if you get it shipped from themI bought 2 jugs....But only because they were on Amazon for $24.98 and free shipping...See what happens
really not bad looking at all..... I would keep doing exactly what you plan toHere's one with some more rocker and the plug tube.
Thanks for posting these photos. I recently bought some R&P to try. I'll see if I get similar results in the top end of my 2008 Mazda MX-5.Did a valve adjustment and gaskets/plug seals on my 04 TL. There was some heavy varnish on the front valvetrain, dirty PCV side. It's been about 1k mi since and I'm seeing very similar results to @Fa24wrx . The fasteners were previously all deep honey colored or brown, but I'm beginning to see bright silver zinc. The oil that pools in the recess on the hex heads has suspended grime that has been cleaned from the metal. Springs, rockers, casting, and dipstick are all brightening/cleaning up also.
