Now I patiently wait for them to introduce R&P in 0w30โฆ
Most likely you are mostly correct, However, I still see posts from people that have excessive oil consumption and would like to fix that issue.Good / great oils and the dedicated practice of keeping up with regular oil changes can usually can prevent those things. Sometimes though the design of the engines can make it harder to prevent some things. What we all have in our favor these days is almost every oil you can find is so advanced that we really should not find ourselves dealing with internal engine issues. Good gas / oil can only help.
Why?Now I patiently wait for them to introduce R&P in 0w30โฆ![]()
Why not?Why?
Because it hasn't come out in a 5W-40 yet.Why not?
He lives in Alaska so if anyone needs a 0w30 itโs him.Why?
And 5W-30 won't cut it? Not likely.He lives in Alaska so if anyone needs a 0w30 itโs him.
I would definitely rather have 0w30 in the extreme cold up there and obviously he feels that way too.And 5W-30 won't cut it? Not likely.
Because it gets to -40 at night and with 0w30 or a 0w40 my vehicles start right up without the need of a block heater.Why?
Minor FIFY.Because it hasn't come out in a50W-40 yet.
Says a man in Daytona Beach (very nice area BTW).And 5W-30 won't cut it? Not likely.
I've been wondering that as well as my truck calls for a dexos oil.Valvoline says the oil is also their top choice for new engines, so why wouldn't they have it approved for Dexos 1 Gen 3, thereby expanding their potential user base?
they are probably referring to the EP or the advanced oils in proper viscosity,as they are dexos gen 3,the R&P can be referenced as a specialty oil, at least for now?Valvoline says the oil is also their top choice for new engines, so why wouldn't they have it approved for Dexos 1 Gen 3, thereby expanding their potential user base?
Someone asked if anyone thought itโd help with intake valve deposits a page or two ago.How in the world did this thread switch from oil ring deposits, to intake valve deposits?
I called tech support about this question, and the reply was that any carryover into the intake and to the valve would indeed help remove deposits.Someone asked if anyone thought itโd help with intake valve deposits a page or two ago.
You could go for 0W-20 in the winter time. The 20 grade in cold AK weather would probably be fine since oil temps will be down.Now I patiently wait for them to introduce R&P in 0w30โฆ![]()
That's the same response I got.I called tech support about this question, and the reply was that any carryover into the intake and to the valve would indeed help remove deposits.
