If Mobil, Pennzoil and other name brands didn't have regular rebates, I would be running SuperTech no question. It is good oil.
True, but you can meet a spec, and you can also exceed it.
I don't think it would be fair to state that Mobil 1 Extended Performance does not offer any performance advantage over a house brand synthetic.
Have my own report coming soon-ish with Super Tech 5w30 FS and a Super Tech 9688 filter on our Van. First UOA on this vehicle so I'm anxious but she runs great.
I've also run 0w20 Super Tech in my Mazda for 7K miles without issue.
I think one can also argue that the specified drain interval using an "approved oil" is also inadequate. Just look at how nasty some of these VCM engines look after 10K intervals on 0w20 synthetic per the OLM.Only "performance advantage" is a potential longer change interval.
Given some GDI turbo boosted motors and how they can be... Those 15-20k miles sound good... But maybe not the most realistic in certain applications and how they are run.
As noted before... That Warren Distribution made Peak had the lowest CCS at -30°F ever tested... 3,200... Lower than Amsoil Signature Series, lower than Mobil 1 Annual Protection, lower than Pennzoil Platinum... With a additive package that is on par with all of the big oils offered by Pennzoil, Valvoline and Quaker State, Castrol, Chevron Havoline...
It may only be a group III... But it is not a trailer park version of one.
Do you have one ?Turbo boosted motors put fuel in the fuel... Especially when it is cold out.... Dropping viscosity by a decent margin. That is evident on here by many analysis that have shown that consistently time and time again. Repeatedly.
Furthermore GDI turbo boosted motors put a lot more soot in the oil. Be one thing if the oil sump sizes were like diesels with far, far bigger sump sizes. 5-6 qt size has no where near the soot holding capacity like one that is like one in a F-250 much less over the road trucks.
My owners manual on my lone TDI says 9k …To read all the analysis on here... Which is rather clear. Fuel dilution is common.... Especially in places that are colder than Corpus Christi...
Nothing wrong with those motors. They just have different considerations vs port injected motors.
The old S10s and Blazers with 4wd [pre-2003 vintage] have a pretty cool hinged plastic access door for the oil filter in their under pan. You could grab one of those at the junkyard and graft it on.That car is a royal pain to change oil (huge under pan on hybrids) …
The manual calls for 5w30 …Seriously... That does not mean it will legitimately actually make it that far.... Others recommended oils were proven to be incorrect later on.
Just like batteries... They don't last as long in Brownsville Texas as they do in Duluth Minnesota... The heat in Texas kills batteries... Up north the cooler temps seen helps them last longer...
In correlation to turbo boosted motors...
What may work in Corpus Christi.... May very well not work on Duluth Minnesota... Or even in my area..
Remember... Ford recommended 5w20... In the owners manual... Only to change that later to 5w30 because there were problems with the 5w20.
