edyvw
$50 site donor 2025
Maybe this question was asked, but why you do not change it yourself?
Yes, but you failed to recognize it's a trick question (for dealer) on purpose.If they used a GF-6 oil then 0W-20 is GF-6A by definition.
I bet ya that TGMO 0w16 API SN/RC is really a GF-6B in the bottle.I was making the point that the API statement says GF-6B is not backwards compatible. I'm sure it's a poorly worded statement only meant to apply to cars that speced 0W-20 and not 0W-16 (Pre-GF-6B) but that's what it says.
Since Toyota is part of ILSAC I look for them to have GF-6B on that oil shortly.
Since Toyota dealers don't always use Toyota oil I hadn't really thought about whether it was TGMO.
The logic follows that 6A's are back compat with previous GF's, but they specifically call out 6B's WILL NOT be back compat with previous GF's.GF-6A is backwards compatible and is a direct replacement for the existing GF-5 category
GF-6-B includes the new 0W-16 viscosity grade and will not be backwards compatible to cover previous GF specifications
Why all of a sudden the api.org site says the GF-6B is back compat but 1,000 other sites out there say "no it's not"?
And to boot, if GF-6B's were back compat, then why not just say they are back compat and not words that say "it can replace API SN and API SN/SN+"? Are there any 0w16's that are not SN or SN+ ???
And right in post #1 of this bitog thread
https://www.bobistheoilguy.com/foru...-low-viscosity-engine-oil-q-a-answers.312544/GF-6A is backwards compatible and is a direct replacement for the existing GF-5 category
But they called it out in specific words, why not just say "is back compat"?What do you think "can replace" means? Basic logic says that "can replace" = "back compatible".
I only listed the table API has on their site. It specifically says SP is for GF-6A. Maybe a goof on their part? You trying to shoot the messenger.API SP covers both GF-6A and GF-6B. When the bottles come out, you'll see that. If API SP only covered GF-6A, then what's the API rating for GF-6B?
You really think the API website information is false? If the API doesn't know, nobody does.
But let me ask, is there a HTHS spec range for API SN or SN+?
New cars only use synthetic oil. You can't have TGMO 10W-30 in this car, which is conventional. TGMO 0W-16 isn't available in draft—it's only available in bottle.If the dealer was any smarter, they would have used10W30 in the heat of CA but I know you are a thinie.
So their printer can't print 0W16 but it can print 0W20? What kind of printer is that? can it print my paychecks?
You should have asked them to show you the barrel of 0W16 and also made sure they shake it.
It can't be GTL or PAO because ExxonMobil always identifies them in the MSDS.Most probably GTL or PAO. Looks like the new Mobil Super Synthetic.
TGMO 0W-16 SP ExxonMobil
Name CAS# Concentration* GHS Hazard Code
Alkylene aromatic amine 36878-20-3 1- Di[alkyl (C=14-18)-2-hydroxybenzoic acid] mosquito Lucium salt 114959-46-5 0.1- Benzoic acid, 2-hydroxy, mono(C>13) alkyl derivative calcium salt (2:1) 83846-43-9 0.1- Polyolefin amide Alkyleneamine borate 134758-95-5 1- Highly hydrogenated heavy paraffinic oil distillate 64742-54-7 50-COLOR] H304
What is the missing 20%? Group V AN and/or POE?
Alkyl dithiophosphate zinc 68784-31-6 1-
That Mobil Super 0W-16 MSDS is indeed identical to the TGMO 0W-16 SP MSDS in Japanese. They are probably the same then. We can look at the four-digit RN numbers on the bottles to confirm. I wonder if the American TGMO is different than the Japanese TGMO, even though they are both made by ExxonMobil. Perhaps Toyota Japan buys bulk Mobil Super and puts it in TGMO cans.
Right(yes). I asked it because I was looking for a reason why a grade of oil might not be backward compat. when the grade is part of a newer "special" category.No, HTHS ranges/minimums are associated with the viscosity ratings, not API ratings. Go find and look at SAE J300.
If ambient daily air temps are in range of 80F(low) to 118F(hi), why is a 0w16 needed? The car being off for days in my driveway will have the oil up near ambient (100+) even before I start it. Would a 5w30 be ok?There is no need for thicker oil unless the car is driven hard.
I did not take 6B to mean 0w16 only (restricted). It is said 6B currently only has 0w16 in it, but 12' 8's & 4's might jump in later. Also some chatter about a 6C category. Maybe a better way to say it is "0w16 is in GF-6B". Why can't a 5w16 get into 6B?GF-6B is restricted to 0W-16 only, and you can't even have 5W-16 in GF-6B.
These are the official API 1509 documents. See the first one (engine-oil licensing and certification system), pages 74, 131, and 135. 0W-16 is explicitly part of API SP. GF-6B is restricted to 0W-16 only, and you can't even have 5W-16 in GF-6B.
So how did all this "GF-6B not back compat" stuff get out there?
