2019 Skyactiv G 2.0 120 oil
Manchester UK
Hello all there.
1st proper post.
I have a 2019 Mazda CX-3 2.0 120 with 21000 miles and I have an oil quandery.
Now I have seen the existing "Oil for 2.0 Skyactiv - Battle of the 0w-20" Thread, but that's for US market oils.
I'm in the UK so it needs to be oils available in Euro land.
Oil specs for the car per the manual is API SN and 0w20 or 5W30 ( I hear SP has replaced SN? )
When I got it had fresh Millers XF C5/C6 0w20 API SN
But I changed it to Millers EE performance 5w30 API SN/C3
She is a little rattly in the mornings, more that what I think would be normal, Skyactiv's also take ages to warm up.
My drive to work is a 10 minute 5 mile bimble at no more than 30mph = 10 miles a day
I drive it every other Saturday, 50 mile motorway round trip to my father at 70mph
With usually about 50 to 100 miles of lightly spirited driving as we go out for the afternoon.
So that's 250 miles of bimbling and 300 miles of motorway and mild A road mild thrashing every month
Looking at the specs for the Millers EE, it is a very thick 5w30, so I suspect might be a bit too thickm plus the low pour point makes me suspect is a very very mid range Semi Synthetic with a big add pack.
  • AE Viscosity 5w30
  • Specific Gravity (at 15°C) 0.856
  • Kinematic Viscosity (at 100°C, cSt) 12.4
  • Kinematic Viscosity (at 40°C, cSt) 71.9
  • Viscosity Index 172
  • Pour Point (°C) <-30
  • Flash Point (°C) >200
  • Cold Crank Viscosity (cP) 6,600
  • TBN (mg KOH/gm) 6.66
  • HTHS (mPa.s) 3.58
So wanting to swap to a good lower thickness 5w30 or a very good thicker 0w20
My initial research suggests this
TotalEnergies Quartz Ineo Xtra Long Life 0w-20​
https://cdn.opieoils.co.uk/pdfs/tot...TYwMTAkbzEzJGcxJHQxNzUzMjk2MjgzJGo1OSRsMCRoMA..
Viscosity grade - SAE J300 0W-20
Kinematic viscosity at 40°C mm²/s ASTM D445 40
Kinematic viscosity at 100°C mm²/s ASTM D445 8.1
Viscosity index - ASTM D2270 183
Pour point °C ASTM D97 -66
OC Flash point °C ASTM D92 230
But I am here to learn more and see suggestions of people who know way more than me,
I've used 0w-20 through 5w-40 and just about every viscosity in between in three different in and out of warranty Skyactivs 2.0/2.5's over the years. I've even used 15w-50 in a pinch short term. Not one of them made a noticeable bit of difference as far as mileage, warmup time, drivability, etc.
I would also disagree with Skyactiv's taking forever to warm up. None of mine ever have or currently do. All of them have a distinct, louder exhaust tone on a cold start, that very quicky goes away as it warms up. Other than that, nada.
The old oil is out, fresh TotalEnergies Quartz Ineo Xtra EC6 0w-20 Synthetic is in.
Old oil has not been sent for testing, Millers oil test kit just ordered, I asked the mechanic his opinion on what came out.
Told him it was 700 miles old, he told me the old oil is cooked, and no way could it it get that bad in just 700 miles unless something was badly wrong with the engine, or I was lied to over it being changed on past 2 changes (I supplied the oil for the middle change)
There was pre sale oil change by the dealer at just over 20000k (now suspicious if this ever happened)
I got it changed at 20550 (now suspicious if this ever happened)
And today at 21300, I watched todays oil change from the waiting room, this one was done.
There was pre sale oil change by the dealer at just over 20000k (now suspicious if this ever happened) Millers XF 0w20 C5/C6
I got it changed at 20550 (now suspicious if this ever happened) Millers 5w30 EE C3
Oil test result is in
Would like the expertise of the forum please
The 8ppm Aluminium looks good
But the oil was only 700 miles old
