wemay
Site Donor 2023
5W-30
10W-30
No bearing on the operational viscosity (thickness) of the oil (cSt@ 100*)
10W-30
Even less difference than 5w30 vs 10w30.
0 to 100C
40 to 100C
-40 to 40C
I was so surprised that they were so close at 40. It was the lowest measurement I had for comparison.5W-30
10W-30
I'm starting to think that all the 0W-xx, 5W-xx and 10W-xx oils (where xx is the same hot viscosity rating) are going to be basically the same "viscosity vs temperature" from 40C and higher (as seen in the examples I plotted). Maybe that's why they have chosen 40C as one of the viscosity temperature points in the specs.I was so surprised that they were so close at 40. It was the lowest measurement I had for comparison.
I definitely agree and thats why I also wish they included 0 also or even instead. Even in areas where its 40C, its not that all year round. Even in Florida or Texas, I think it ocassionally approaches freezing, and cold is where you really want to know the flow.I'm starting to think that all the 0W-xx, 5W-xx and 10W-xx oils (where xx is the same hot viscosity rating) are going to be basically the same "viscosity vs temperature" from 40C and higher (as seen in the examples I plotted). Maybe that's why they have chosen 40C as one of the viscosity temperature points in the specs.
Yes certainly, at the temperature of your winter rating, none of your bearings are going to be on the operational viscosity.5W-30
10W-30
You got anything better, like measured viscosity at many other temperatures besides 40 and 100C to determine just how "fictitious" Widman's curve generator is?Actual regression is molded by choice and combination of VM these days. You cannot be serious in discussing the fictive curves derived from KV40 and KV100 – but yes, by zooming out from the once plotted fiction you can certainly progress to a discoidal world of xx-viscosities, turn that around and expect anything you like for 40C and below. Just do it, somehow they all fit the big NIKE curve...
We know that visc calcs don't work much below 0C, so I'm not sure what the point is of trying to run it down to -40 and play "Gotcha!"You got anything better, like measured viscosity at many other temperatures besides 40 and 100C to determine just how "fictitious" Widman's curve generator is?
Can you give info/data that proves they don't work well below 0C? ... ie, real viscosity vs temperature measurements shown against the calculator model output.We know that visc calcs don't work much below 0C, so I'm not sure what the point is of trying to run it down to -40 and play "Gotcha!"![]()
Most of those 10 oils shown they act very similarly with temperature change. Odd ball oils don't necessarily define the whole phenomenon, especially when the VM formulations of "oil #1 thru oil #10" isn't defined.Not even for 65°C this can really work. But tell me anytime how and where below the 40°C above four curves are expected to break so that their CCS inversion is accomodated and your use made of this toy makes any sense.
From the Marx papers:
Just to clarify, the purpose of showing the V vs T plots was to see how 0W-xx vs 5W-xx and 5W-xx vs 10W-xx compared from 40C and above, which showed that the viscosity vs temperature was basically identical above 40C.We know that visc calcs don't work much below 0C, so I'm not sure what the point is of trying to run it down to -40 and play "Gotcha!"![]()
When plugging in KV40 and KV100, the temperature at 19,000 cSt (as data sheet shows for KV-40, not 18,000 like you posted) comes out to -36.1 C. Nobody (even Widman on his website) claimed the calculator was dead nuts accurate ... but being only 4 deg C off isn't bad IMO since viscosity it super sensitive to change the colder it becomes. Besides, use the "W" rating for cold weather oil picking.Sure, I've posted it in the past, I'm surprised you didn't see it in many of the numerous discussions we've had on this subject? Molakule has chimed-in on it as well.
Take a straight PAO base that lists viscosity at multiple temperatures. PAO has no wax in it, so it's about the purest example we can work with here. Bases with wax that can crystallize and require PPD's will not behave as well.
So, using SpectraSyn 8, which lists KV at multiple temperatures:
https://www.exxonmobilchemical.com/en/chemicals/webapi/dps/v1/datasheets/150000000353/0/en
KV100: 8cSt
KV40: 48cSt
KV-40C:18,000cSt19,000 cSt
Plug that in your visc calc and it shows 33,262cSt at -40C.
Feel free to try this with some of the other bases. The only one that plots correctly is SpectraSyn 2, all of the others are off massively. And now, again, consider we are using pure PAO which has VERY predictable performance and a fully formulated lubricant won't behave even remotely close to as predictably.
As far as "running it down to -40C", can anybody please show me where an oil rated at 0W-xx has a higher viscosity than any oil rated at 5W-xx, or an oil rated at 5W-xx has a higher viscosity than any oil rated at 10W-xx anywhere below say 0C. I highly dougt there are any, because if there was they wouldn't be rated at 0W, 5W or 10W to start with.
I SPECIFICALLY used straight PAO because it was going to be the closest, and even it was WAY off. Now consider the impact of wax crystal formation, PPD's, VII's, additive packages...etc. That's why you go by the Winter rating and the available figures for that, if possible (CCS/MRV), rather than whatever exercise was being performed using the visc calc (which wasn't you doing it, let's be clear on that point).
Being off 4 deg C for KV-40 when viscosity change is super sensitive at those temperatures isn't too bad IMO. Obviously, there's a reason or two the oil makers don't show the KV at temperatures that cold level, because a few degrees can make a huge viscosity difference ... not so much at say 40C and above, or even 0C and above.
