2020 VW Jetta 1.4l Turbo
Oil cap states 0w-20, however when I enter the VIN at the VW website for the online owners manual, and what one would consider the most current publication (Owner's Manual, GLI, Jetta, January 2020, United States version, model year 2020) it states:
Gasoline engine: Standard ACEA A3/B4 or API SN (API SM) and viscosity grade SAE 0W-30.
Which is fine. I have a gallon of Mobil 1 Delvac 5w30 with a API SP rating, although it is also a HDEO. Nice thick 5w30 with a stout add pack.
My question is about the TBN level of 11. Any concerns with that number being too high? Car has around 70k miles now and if I use this oil I'd probably extend the OCI to a 8k to 10k range.
Properties and Specifications Mobil Delvac1 Advanced Synthetic
| Property | |
| Grade | SAE 5w30 |
| Kinematic Viscosity @ 100 C, mm2/s, ASTM D445 | 12 |
| Kinematic Viscosity @ 40 C, mm2/s, ASTM D445 | 73 |
| Cold-Cranking Simulator, Apparent Viscosity @ -30 C, mPa.s, ASTM D5293 | 6430 |
| Mini-Rotary Viscometer, Apparent Viscosity, -35 C, mPa.s, ASTM D4684 | 19700 |
| Hi-Temp Hi-Shear Viscosity @ 150 C 1x10(6) sec(-1), mPa.s, ASTM D4683 | 3.6 |
| Viscosity Index, ASTM D2270 | 160 |
| Ash, Sulfated, mass%, ASTM D874 | 1 |
| Total Base Number, mgKOH/g, ASTM D2896 | 11 |
| Pour Point, °C, ASTM D97 | -42 |
| Flash Point, Cleveland Open Cup, °C, ASTM D92 | 241 |
| Density @ 15 C, g/ml, ASTM D1298 | 0.851 |
