Castrol 10w-30 vs Mobil 15w-40
western australia
Hi
Been a long since last post
Help choose an oil between the Castrol Magnatec Stop-Start 10w30 or Mobil Super™ Everyday Protection 15w40 below.
Vehicle Holden commodore 3800 V6.
Over 250000 kms
City driving, trips vary between 10 t0 20km trips
Climate 3 to 25 deg C winter
I am leaning towards the Castrol 10w30 as the 100 deg CP is 12.4 and it is rated SN and A3/B4.
It almost a thin 40 wt,
Any advantage of 15w40.
See oil specs below
Typical Characteristics
Name Method Units Castrol Magnatec Stop-Start 10w30
Density @ 15C, Relative ASTM D4052 g/ml 0.869
Viscosity, Kinematic 100C ASTM D445 mm²/s 12.4
Viscosity, CCS -25C (10W) ASTM D5293 mPa.s (cP) 6640
Viscosity, Kinematic 40°C cSt ASTM D445 cSt 84
Viscosity Index ASTM D2270 None 142
Pour Point ASTM D97 °C -39
Flash Point, PMCC ASTM D93 °C 202.5
Ash, Sulphated ASTM D874 % wt 1.22
Product Performance Claims
ACEA A3/B3, A3/B4
API SN
OR
This product has the following approvals: MB-Approval 229.1 VW 501 01 VW 505 00
This product meets or exceeds the requirements of: API SJ API SL API SM API SN API SN PLUS ACEA A3/B3
Properties and Specifications
Property
GradeSAE 15w40
Density @ 15.6 C, g/ml, ASTM D40520.873
Total Base Number, mgKOH/g, ASTM D28969.9
Viscosity Index, ASTM D2270143
Kinematic Viscosity @ 40 C, mm2/s, ASTM D445104
Hi-Temp Hi-Shear Viscosity @ 150 C 1x10(6) sec(-1), mPa.s, ASTM D46833.9
Mini-Rotary Viscometer, Apparent Viscosity, -25 C, mPa.s, ASTM D468414600
Pour Point, °C, ASTM D97-39
Ash, Sulfated, mass%, ASTM D8740.9
Flash Point, Cleveland Open Cup, °C, ASTM D92239
Kinematic Viscosity @ 100 C, mm2/s, ASTM D44514.5
I had a 2004 Commodore myself - I used to use 10w40 (Nulon) in the colder months and 10w50 (penrite) in the warmer months.
In hindsight I wouldn't go thicker than 10w40
I think it was quieter on the thicker stuff - Between your choices and given the kms, go with the mobil 15w40
(Though do recommend the 10w40 Nulon 'Fast Flow' especially when on sale) - Picked up 5L for $28 recently
Looks like I have to be that guy...
What does the manual say about engine oil specifications? Any oil consumption between services?
The OEM Manual states 10w30.
The owners manual states the following which is the same note I have extracted from Mobil's lube match site for ease of cut and paste
Note
If MOBIL SUPER 1000 10w30 * is unavailable, use MOBIL SPECIAL 20W-50 * or MOBIL SUPER 1000 20W-50 for normal driving, or MOBIL SUPER 1000 X2 15w40, MOBIL SUPER 1000 DIESEL 15w40, MOBIL DELVAC MODERN 15w40 FULL PROTECTION * or MOBIL DELVAC MX ESP 15w40 for prolonged use in cold (snow) areas. With LPG engine, use MOBIL DELVAC MODERN 15w40 FULL PROTECTION *, MOBIL DELVAC MX ESP 15w40 or MOBIL SUPER 1000 DIESEL 15w40 meeting Spec. No HN2314.
That 15w40 is thick enough for the engine. Australia is a pretty warm place in all seasons.
I live in Texas. My Isuzu p/up takes those viscosities, but I'll take the 15w40. Australia is in for a winter months so take the 10w30
I've used the semi-synthetic Castrol Magnatec 10W30 (API SN & ACEA A3/B4) before, I found it very smooth running. If it's at a good price, then I would grab it.
Severe condition (extreme hot weather, pickup etc..) use the 15w40 grade. Otherwise use 10w30.
I don't get it. I would never run hot heavier than owners manual. Like never 40 when mfgr says 30.. except a guy here says he can hear pin noise !?!? If I was in Iraq .I would run what warranty/manual says. That said I think all mfgrs(engineers) have sent out bulletins recommending using 0W instead of formerly specified 5w. No I don't have lab report tested fleet used oil. How many here assure there new filters are installed wet and all your zerks get greased? My dad got 500000miles..1953 BuickSuperV8 w/Dynaflow. But lost the original differential at 130000..he never changed rear end lube. That was awake up call. He ran Shell 10w30 burned 1qt at 3000. ..then he'd change oil and filter and lube zerks anyway. Oh.. the Nailhead had one fussy lifter that would quietly click if it did not get a drink of CD2 every 18000? Miles.
Please try and make a technically cogent response.
