Here’s my 15 Tacoma 4.0L at 132K. Amsoil XL 5W30 (5500-6500) oci. A few 10K runs with SS 0W30. Doesn’t burn a drop. View attachment 199654
Amazing!
17 Corolla and I go 7-10k which amounts to every 6 months. I do 60 miles roundtrip every day. About 45 of that is highway speed the rest town. So pretty easy on oil. Last summer I did a ton of in town driving and changed at 5500 before November. At about 100k now and I've rebuilt the engine 11 times because I go more than 5k per change.Both my 19 and 21 Toyotas were bought new so they had the Toyota recommended oil changes at 10K 'at the dealer. Since I am now on my own I am curious if a 10K interval is just fine for everyday driving or going to 5K or 7.5K for oil and filter is better?
Greetings from salty NY north of I-90. I'm a degreed mechanical engineer from RPI who's now 53, working in API compliant rotating equipment, who's had the pleasure of meeting Shell engineers in technical meetings and who's also been fortunate enough to ask that single Shell PhD who derived my employer's gearbox isovg32 oil and additive package a very important question at the end of his presentation "what do you do in your own personal vehicle for OCI and type?". The answer? "Full synthetic and treat every car like it sees severe duty.". His response carries a lot of weight. I listened. I've had four Camry (latest 2018 LE) and four Honda (last was an 07 Civic LX AT (sold at 402,000, mostly highway, 8k OCI) with the latest current being a 12 Civic LX MT(currently at 180,000, using 5k OCI) and my girlfriend has an 05 Highlander with 240,000 on it now ( 5k OCI). The '18 was a CPO car from a dealer in Oneonta who, showed me prior owner service records from when it was a lease with an OCI of.....every 5000! That was a lease I bought at 32,000. So why would that dealer follow 5k and another would follow 10k? One is planning for the average driver's style and the other wants to save money. Guess what my employer does? It competes with other equipment manufacturers that boast they also have the lowest ownership cost...and...will also state the "minimum recommended maintenance schedule"....trust what The Car Care Nut and other folk on here recommending 5k max OCI, unless 1) your car never sits overnight below 70F, 2) never rolls in city traffic, 3) never sees rpms over 2,000, 4) has its oil level checked weekly, 5) gets run daily for 20minutes minimum 6) only sees top tier gas .....hopefully you see my point....perfect operating conditions including storage that ensures no condensation with fuel that has valuable detergents...all these things matter. I use Penn Ultra Platinum with a Mobil filter and on the highway vehicles (the '12 Civic mainly) I'll change the filter every other, like Honda allows. (Note there is no Penn Ultra or Amsoil Signature Series available for the Camry required 0w-16). I do believe The Car Care Nut when he says the 18&19 Camry engines are sensitive....I will not be pressing my '18 Camry's luck. Hope this helps. The above PhD was basically a tribologist. If you'd like to YouTube The Motor Oil Geek, you will find the same recommendations from Mr. Lake Speed Jr. who is also a tribologist and has even been so kind as to reply to my DM questions where one response is valuable sharing here paraphrased: " pumping is different than pouring, don't waste time worrying about cold pour tests unless you are living north of Edmonton Alberta Canada."Thanks for all the feedback. Both vehicles I have are driven normally as far as mileage and conditions. Bought the REAL Toyota extended service plans for a great price and just curious if 10K is bad why they would cover a vehicle following their oil change recommendation of 10K? When I was a kid everything was done at 3K or 6 months but the dealer told me it was overkill for today's vehicles. I have also learned that those Blackstone reports are kinda like JD Power Associates in that their results have been challenged similar to K&N stating that their air filters equal more HP!
Just keep in mind that just because Toyota does not use the term nor list any criteria doesn't mean Honda is wrong for doing so. Please see my other comment to this OP. I've had both Toyota and Honda and overall I definitely consider the Honda engine particularly in the Civic to be the more durable engine. You can't prove you've over-maintained anything until you've had a failure that makes you regret you didn't do more....5k OCI is super cheap insurance is it not?I do 10k oil changes as recommended for my Tacoma and my Corolla cross hybrid (prius drivetrain) Most people “do not” fall into Toyotas defined special operating conditions as Toyota spells them out in their maintenance manuals. Toyota does not use the term “severe service”.
over maintenance has no quantifiable benefit.
The number of times I've heard a person with a degree in mechanical engineering introduce themselves as such makes me wish I'd never gotten two degrees in mechanical engineering.Greetings from salty NY north of I-90. I'm a degreed mechanical engineer from RPI who's now 53...
Yeah I was there with him until he implied you can only run 0w-16 in a Camry.The number of times I've heard a person with a degree in mechanical engineering introduce themselves as such makes me wish I'd never gotten two degrees in mechanical engineering.
Hold on everybody, smart person has entered the room. Opinions as knowledge forthcoming.
How long is that service plan / warranty? 5 years and 75k miles?Bought the REAL Toyota extended service plans for a great price and just curious if 10K is bad why they would cover a vehicle following their oil change recommendation of 10K?
I didn't read past the introduction. It was a guarantee that nothing good was to follow.Yeah I was there with him until he implied you can only run 0w-16 in a Camry.
This guy...........he's not an idiot, but some of his stunts are a bit odd, and he's all over the map.If you'd like to YouTube The Motor Oil Geek, you will find the same recommendations from Mr. Lake Speed Jr. who is also a tribologist........
I know several mechanical engineers that don't know much about automobiles or mechanical related things in general. Just because you are a mechanical engineer doesn't mean you are mechanically inclined.I didn't read past the introduction. It was a guarantee that nothing good was to follow.
Its 10 year 100K on both bumper to bumper. Mainly bought to protect against electronic/computer issues.How long is that service plan / warranty? 5 years and 75k miles?
I'd expect a suzuki to make it that far on 15k OCIs. I bought I toyota because I have far greater expectations than 5 years, 75k.
Edit to add I didn’t realize I already responded to this post.Both my 19 and 21 Toyotas were bought new so they had the Toyota recommended oil changes at 10K 'at the dealer. Since I am now on my own I am curious if a 10K interval is just fine for everyday driving or going to 5K or 7.5K for oil and filter is
Mechanical engineer here, follower of Lake Speed Jr The Motor Oil Geek, I work in heavy API rotating equipment and do all of my own work... successful in getting numerous vehicles to very high mileage...and I own an '18 Camry. The 18 Camry has an electric variable flow oil pump as well as coolant pump...the engine is also partial direct injected and sensitive to dirty injectors causing oil dilution and I know this because it happened to my car. Top tier gas always, Chevron Techron every 3000mi on any engine that had any sort of direct injection, and oil OCI 5000mi or less.....it really is simple and a complete waste of time and money and added risk to do anything other than that. Doesn't matter who makes the oil, get it gone...there's no magic oil. Consider Valvoline restore and protect as well although I don't think Penn Ultra Platinum is bad either. R&P definitely keeps rings free.Both my 19 and 21 Toyotas were bought new so they had the Toyota recommended oil changes at 10K 'at the dealer. Since I am now on my own I am curious if a 10K interval is just fine for everyday driving or going to 5K or 7.5K for oil and filter is better?
