Australia and I think 2022. Though the engine hasn't been changed with any bearing clearance difference just re tested to work with 0w-8 in the most latest models without excessive wear or at least what Toyota calls excessive I don't know for sure.
I'm ashamed of myself, I need to up my thickie game. I should run 50 instead of 40 in everything too.Awesome thanks!
I live in seriously hot South Texas where 9F is the historical low in 1989 and 90-105F is the common temp through most of the year. I run Mobil 1 15W50 AFS in all my other cars and bikes down here, actually saw a very consistent 0.5mpg improvement in my 2014 Ford Edge switching from recommended 5W20 Mobil 1 synthetic to Mobil 1 15W50 synthetic. Recently picked up a a 2020 ICE only Rav4 with the A25A-FKS and a bit under 60K miles and I did Mobil 1 0W40 for my first oil change, but I think I am going to switch it over to the 15W50 next oil change too just for simplicity sake.
They make 10w60 for a reason.I'm ashamed of myself, I need to up my thickie game. I should run 50 instead of 40 in everything too.
That’s impressive. Haven’t seen anyone around here with the plums to run a 50 weight in a while.Awesome thanks!
I tried it for an OCI in my Tiguan to see if it helped with consumption. It didn't.That’s impressive. Haven’t seen anyone around here with the plums to run a 50 weight in a while.
How much are you consuming?I tried it for an OCI in my Tiguan to see if it helped with consumption. It didn't.
Did the Valvoline Restore and Protect help?I tried it for an OCI in my Tiguan to see if it helped with consumption. It didn't.
I don't know the exact amount, but it is probably about 1 quart in 1500 miles. It depends on driving conditions. When the vehicle was brand new it used a little at first but then settled down to nearly zero in 5000 miles. But then at some point it just jumped up again, and I think it is the valve stem seals as I see a puff of smoke when started. This wouldn't be the first VW engine I've owned that needed the stem seals replaced. I'm a little intimidated with putting it all back properly if I change them out, so I've been dragging my heels a bit getting it done. It also needs the water pump and housing replaced.Did the Valvoline Restore and Protect help?
Why do you think you developed oil consumption? I'm certain that you've been running quality Euro oils with stringent approvals since you've had it.
More importantly, how is the oil consumption rate at 10k? Any oil added, how much?My 2020 RAV4 get its oil changed every 10k miles with 0w20. Mostly Kirkland and some Valvoline. Has 140k miles on it and runs fine.
That's a big job. You have to take the head off for that right? Impressive work to tackle yourself.I don't know the exact amount, but it is probably about 1 quart in 1500 miles. It depends on driving conditions. When the vehicle was brand new it used a little at first but then settled down to nearly zero in 5000 miles. But then at some point it just jumped up again, and I think it is the valve stem seals as I see a puff of smoke when started. This wouldn't be the first VW engine I've owned that needed the stem seals replaced. I'm a little intimidated with putting it all back properly if I change them out, so I've been dragging my heels a bit getting it done. It also needs the water pump and housing replaced.
I don't think it has an issue with the oil causing carbon or stuck rings. I think it is a mechanical issue.
It stays on the f line to about 1/4 qt low when I change the oil. I've never needed at add any top off oil. We drive a lot of highway miles.More importantly, how is the oil consumption rate at 10k? Any oil added, how much?
But you do acutally add 4.8 qts when you change the oil or 5 qts?It stays on the f line to about 1/4 qt low when I change the oil. I've never needed at add any top off oil. We drive a lot of highway miles.
I add 5 qts and it takes it right to the F line. It's almost time for an oil change at 140,000 miles so I'll pay closer attention.But you do acutally add 4.8 qts when you change the oil or 5 qts?
That's interesting. I wonder if you change the oil on an unlevel surface. Or is this before you start the engine and fill the filter?I've got the same engine, however, if I filled it up with 4.8 qts it's already 1/4 over the F line. So, at 5 qts, it will be over 1/3 F.
This is changing the oil on ramps and after starting the vehicle.That's interesting. I wonder if you change the oil on an unlevel surface. Or is this before you start the engine and fill the filter?
Have you checked it after the car is level again...This is changing the oil on ramps and after starting the vehicle.
