Originally Posted By: Obos
But by definition there is a spec ie grade, API/ILSAC
And there is then a recommendation
So in that way it's the same, just a little more flexible if anything
Yes, but in such a vehicle, you can use any SN/GF-5 0w-20, since that's what the manual calls for. From the warranty perspective, there's absolutely no difference between PU 0w-20 and the dealer supplied oil.
With respect to Mobil's mainstream API/ILSAC oils versus those with the European specifications, remember that they are often mutually exclusive. You're not going to get an ACEA A3/B3 or A3/B4 type oil that's going to also have a GF-5 ILSAC rating.
All the fancy European proprietary numbers mean an oil simply isn't going to be ILSAC approved for the average North American or Japanese vehicle. The only ACEA specs I ever see combined with SN/GF-5 are ACEA A1/B1.
Anything with A3/B3 or A3/B4 is simply too thick to get ILSAC GF-5. Note that most "North American" oils that do have either of those specifications are high mileage oils and lack GF-5 certification. Look at the MaxLife Synthetic PDS. It lists ACEA A3 and claims it meets GF-5 engine and emissions system protection requirements; of course, they make no mention of the fuel economy requirement.
