Originally Posted By: CATERHAM
If the engine is spec'd for a light high VI oil then there is no issue, the viscosity demands are being met plus a large safety margin. If thinking of running a light high VI oil in another application it's always prudent to have an oil pressure gauge just to make sure that you're always maintaining a certain known safe minimum operational viscosity when the oil gets fully hot.
Driving hard doesn't mean in any way that you need to run a heavier (higher HTHSV) oil. If you can maintain your minimum desired operational viscosity which oil pressure is proxy for, then you can certainly run a light 2.6cP oil.
The following is a UOA of the Idemitsu (Honda) (199 VI, HTHSV 2.6cP) I ran a while back in my track car:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2829459&page=1
The engine is actually spec'd for a heavier oil
but since my maximum oil temp's are so well contained (that is the key) I've found it to be preferable to run a lighter oil and enjoy the benefits of improved driveabilty, engine responsiveness and increased power.
. . . The engine has a hard life including track days and fast road work. The engine is started infrequently, months can go by in the winter without the car being started or driven. When it is started the car is always driven enough to bring oil temp's up to at least 75C usually 80C before shutting it down. Maximum street oil temp's are 85C and normal maximum oil temp's on the track is 95C with one session of hitting 105C when the oil was fresh (no time to remove the sump shroud at a track event).
I usually wait until the oil temp's have reached 70C before using max' rev's but not always since it can take 25 minutes to do so.
jfi: 70C=158F; 75C=167F; 80C=176F; 95C=203F; and 105C=221 -- oil temps that (save 221F) are quite low and thus easily within the operational viscosity of
any 0W-20 weight oil.
However, I take it that the jest of this thread is that the majors, now including the heretofore sainted RDS, have sold their souls to the devil, and they are more than eager to distribute marginal products to an unsuspecting public to make a buck. Got it.
