Originally Posted By: Gokhan
Originally Posted By: buster
http://www.epc.shell.com/Docs/GPCDOC_X_cbe_24855_key_140007466171_201212050515.pdf
Mighty impressive specs. Looks to be the new juice on the block.
NOACK is impressive, clearly indicating that there is PAO (Group IV) in the mix.
On the other hand, 40 C viscosity is not impressive -- you will see little benefit of "0W" in 0W-20 in most operating conditions, except really cold starts.
Due to its very low NOACK, this oil would be suitable for turbocharger-equipped engines. Its low VI also indicates only modest use of VIIs, which is also good for deposit and sludge control.
If you have a high-performance or turbo car, this should be a good oil, despite the very low viscosity. It's also good for extended-drain applications because of its PAO content and low NOACK.
I definitely give thumbs up to Pennzoil for finally formulating a mainstream 0W-20 with low NOACK for a change, which would be good for even turbo engines.
However, I will stick with the Toyota 0W-20 SN, which has a far better VI and is probably more optimized and better engineered, as the Toyota engineers work together with ExxonMobil to formulate the Toyota oils. More VIIs help with the viscoelasticity of the oil and therefore increase the oil-film thickness substantially, and the high VI results in better fuel economy. I also think that ExxonMobil has the Infineum trinuclear moly in the Toyota 0W-20 SN, which should increase the strength of the antiwear film many times compared to other types of moly and antiwear additives, resulting in great protection against wear.
I think you covered it all.
