Welcome Skiman747 to the land of OCD.
Your 2019 owners manual states: "Engine Oil Viscosity (SAE Grade) — 2.0L Engine Mopar API SN PLUS Certified SAE 5w30 Full Synthetic
Engine Oil which meets the requirements of FCA Material Standard MS-13340 is recommended for all operating temperatures. This engine oil improves low temperature starting and vehicle fuel economy."
2022 manual states: "We recommend using Mopar® API SP/GF-6A Certified SAE 5w30 Full Synthetic Engine Oil which meets the requirements of the manufacturer Material Standard MS-13340. Equivalent full synthetic 5w30 API SP engine oil can be used but must have the API Donut trademark Ú page 255."
It seems that SP supercedes SN+. What is confounding is the MS-13340 standard. Mobil 1 and Castrol Edge list it, Pennzoil does not. Let us know what you find out.
Edit: OP might have an old bottle of SN, that is neither SN+ or SP. Should he use it?
Also, Pennzoil removed the 13340 from the current spec. sheets.
