Originally Posted By: phlfly
yes I agreed it's important of course but viscosity is resistance of flow, so high HTHS is produced high resistance to flow, so it's lead small volume of oil so it turns out the heat is not dissipating fast enough to the oil, so metal is getting heat spots.
Studies showed that double viscosity grade will cause as much 20C rise in oil temp. So the shear thinning can be good and bad , as I mentioned before, but I think Germans recommended high number HTHS due they are looking for 15,000 miles and still be in 3.0, so thier LL01 is more 3.5, when Mobil 1 is 3.2. But if you are not driving 15,000 miles on this oil, Mobil 1 should satisfied your engine for 5,000 miles, since LL01 will degradation as low 2.8-3.0 for 15,000 and you will drive at least 5,000 to 7,000 miles on oil that HTHS is about 3.0 anyway.
Well this very interesting read. (
http://books.google.com/books?id=XjTaOqE...ity&f=false)
Somewhere there said 40 grade loses degrading more than 30 grade oil due more concentration VI improver required more to produce -40 oils. So I guess high HTHS has same tendency due same problem as -40 oils.
Again, you are talking about oil losing its HTHS with no data to back it up. Nobody here is going to even consider that this is the case unless you can actually prove it.
When speaking of the HTHS of the oils in question here, we are talking differences of less than 1cP. You make it sound like we are going from 35,000cP to 11cP. We aren't. Your speak of hot spots and the like and massive resistance to flow are all nonsense. The issue is not how thick, but how THIN the oils gets in the bearings under load. The engines in question were designed around a lubricant with a minimum HTHS of 3.5cP, so that is what they want you to run.
But then I've made this point what seems like 100 times so far and you appear to keep missing it and instead decide to keep spouting nonsense about LL-01 oils "degrading" to 2.8-3.0 with no source for this claim and that the Germans have some mystical agenda about OCI length.
newsflash: Many North American auto manufacturers with the advent of OLM's are now spec'ing OCI lengths that are just as long as BMW, Mercedes....etc. Dexos1 is one of those specifications for extended drains based on a vehicle's OLM. Yet it doesn't require a minimum HTHS of 3.5cP. This is because GM doesn't design their engines to require an oil with an HTHS of 3.5cP. Neither does Honda, Toyota...etc all of which do extended drains now.
Many of the Euro marques have chosen to design their engines for heavier lubricants due to the potential for Autobahn use. subsequently, the engines are tested with those lubricants and the performance and longevity of those engines can only be guaranteed by using an approved lubricant for the application. This is why BMW, Mercedes, VW, Porsche....etc all have their own certifications and approvals for motor oil. HTHS is not only a component of some or all of these certifications, but is also a component of the ACEA classification that the oils that meet these spec's fall under.
I don't understand how you think that you know better as to the lubrication requirements for your vehicle than the engineers who designed it and performed EXTENSIVE testing with regards to wear, deposit control and durability.
