High Performance Lubricants Engine Cleaner
I love that this doesn't use harsh solvents. It seems like a much safer way to get rid of sludge and varnish without messing up the seals. Just tossing in a quart for a couple thousand miles is super easy. Definitely worth a shot if you want a cleaner engine without the risk.
The problem is still there. I suspect that it needs physical scrubbing. But anyway I have another 2 bottles of rislone, so I will use it in my next oil change too.
The wire from inside a motorcycle clutch cable, bicycle brake cable, or old fashioned mechanical speedometer with spray carb cleaner worked to chase the buildup out when I did my nephews. They're strong enough to push through, yet flexible enough to follow bends. I've also used them to clean out other small tubes. Just a suggestion if you end up pulling it apart to clean it.
No. In fact the EC is watered down from their regular oils for a more gentle cleaning so you don’t overload your filter.
watered down? - so you can run 6 quarts of it?
Point being it’s made for 1+5 - I have run it 25%?
Base stock and ad-pack are boosted as well …
Would not want anyone to misunderstand that …
It results in a watered down oil sump when run as per the instructions from the company when compared to a full oil change with their PCMOs.
@High Performance Lubricants I purchased two of bottles of HPL EC 30 to be used in a Mazda CX5 NA GDI engine. I have couple of questions.
1. Does the EC 30 works better in a spring or fall OCI for PNW weather (not super cold, but wet rains).
2. I have Mobil 1 Extended Performance 0W-20 and Mobil 1 ESP X2 0W-20 on hand for this car. Which among these two oils works synergistically well with HPC EC 30.
