OVERKILL
$100 Site Donor 2021
Carbon in the ring lands is an expected byproduct of operation, why do you think Valvoline specifically targeted that with R&P? The API and ACEA standards do not include "keep the ring lands spotless" as criteria, there's a "reasonable" limit on the level of build-up permitted over the duration of the test.even supertech isn't bad, it's hot running engines, bad designs, or bad maintenance that cause carbon or sludge.
Some oils are going to be better at keeping this area clean than others, just like some engine designs are going to be more prone to build-up in this area than others. My experience with HPL liberating carbonaceous material is on a HEMI, which aren't known for stuck rings and high oil consumption, but are known for being quite dirty running. I had M1 0W-40 liberate similar material, but not in the same volume, on our old 5.4L Ford 2V, which is not known as a dirty running engine, but was not treated to the same quality of lubricants and had higher mileage.
Honda's VCM V6, the Saturn 1.9L engines, various Toyota engines. These are all known for developing stuck rings and high oil consumption. These are outside the scope of "typical" conditions attempted to be replicated by the API/ACEA testing. That said, @Trav had success with the Honda VCM engines using M1 0W-40, which underscores the ability to counter the impact of certain poor design decisions with a product that is capable of considerably higher performance than simply "meeting the spec".
