First, I'm not saying which camp is right, just some analysis.
Many people here judge their engine's wear rate base on UOA, fine. Now UOA number is a concentration (ppm or whatever), Let's say a car usually need an OCI of 10K, and it will return say 100ppm of Fe (make up number).
Now imagine a another same car same driving habit, the owner decide to dump the FF early, and split it to 3.3K OCI, and see a lowered Fe level (or whatever Pb, Zn), and if it see 33ppm every UOA during the 10K interval, one can say "yeah, Fe level is low, good run", or I can argue if muliply the concentration and the volume, you get the total amount, you add them up, is still the same as the 10K OCI.Shorter OCI by default will yield lower wear number, simply because you leave it shorter time in the sump, eventhough the engine is wearing at the same rate compare to the longer OCI. This is not surprise right?
Of course, whatever said above is made up, but i think you guys get my point, right? conc. does not equal to total amount.
The truth is most of the claim here are opinions, doesn't matter if it's from a plant tourer or engine builder, when we want to make judgement on these kind of matter, hard core scientific process is needed, and We will probably never see these kind of controlled experiment.
But ppls here are right, if it make you fell better, change it.
Oh, Happy Long Weekend, going to a hike now!
