No sorry. It is a 2023, typo. It has the v6. Just bought it.What interval do you change the oil?
No it’s a 2023 not 2024. Sorry typo, it has the V6The I4 turbo?
Ok, I was curious as to if Toyota is going use the 0w-16 on the turbo.No it’s a 2023 not 2024. Sorry typo, it has the V6
I’m considering doing the same in my 2GRFE, but I’m a little hesitant because mine is spec’d for 0W20, which I’ve since changed out to 5W30…not sure I should bump it up the M1 0W40 FS, but it is almost a 30wt anyway. I do 10,000 mile intervals, currently running Amsoil Signature Series 5W30.In my 2GR-FE 3.5L I am working up to M1 0w40 on 5k OCI and 10k oil filter change intervals.
Currently running 0w30 in my 2GR-FE and my 2ZR-FXE.
There is no single oil weight suggested by the manufacturer.Apparently, offering two quality oil options for the manufacturer's suggested oil weight gets a downvote
I have a 2019 with the same engine. Amazing thing here is: 28,000 miles in a year or less! I don't quite have 25,000 yet!I have a 2023 Toyota Tacoma TRD Sport 3.5L V6 4x4 with 28000 miles. I drive 80% highway and 20% in town or country roads. What do you guys recommend for 10K oil change intervals?
The oil cap and manual suggest 0w20 unless under outlying conditions. Thus it is reasonable to recommend 0w20.There is no single oil weight suggested by the manufacturer.
Post #7.The oil cap and manual suggest 0w20 unless under outlying conditions. Thus it is reasonable to recommend 0w20.
Do we know the HTHS for qsup 5w30?5K OCI and 10K with a quality filter.
Bang for the buck--- QSUP 5W30
Do you have nay data to support this claim?If it makes you feel any better Toyota uses Mobil as their supplier, Mobil 1 EP would be my choice if you intend to run an extended interval like 10K.
