Filter change every other oil change - anyone doing it?
I see no upside to not changing the filter at every oil change, other than cost. I buy in bulk, so cost really isn't that big a deal to me. Some will claim Earths resources, etc. That's fine. Everyone has to decide on their own what's important to them.
As I already mentioned, another benefit is that it makes the oil change less messy if you’re not changing the filter and it shaves off some time as well.
A popular and oft discussed topic here on Bitog, I'm surprised you missed them if you like reading through the forums.
Many discuss a Fram filter in particular. Sorry if there are repeats, there are just so many:
O gee...it has been talked about before........ :ROFLMAO: 🍿
Truth be told, as great as this site really is, by this point, there is very little ground that hasn’t been ploughed a time or two. If one’s curiosity has been satisfied, great, give it a pass. If not, keep ploughing! And every once in a while, a genuinely new issue pops up here (e.g. car makers recommending/specifying a new type or grade of oil, like 0w-8). This is not one of them. I would add that this has been a point of debate for literally decades. My first car care experiences came in the mid 1970s. Long story, but maintenance on my Mom’s car suddenly fell to me. It was a 1973 Dodge Dart sedan with the legendary 225 cid Slant-6 engine. It was already a bit sludgy when it came into my care (at first, I thought that shiny black stuff around the rockers was some sort of grease!!!😳), and I was concerned about the manual’s advice to change filters every other change. As noted above, for modern engines, skipping filter changes, if the engine is clean and the maker recommends it, is certainly safe. If the engine appears dirty for whatever reason, to any extent, I wouldn’t do it. Still, the Owner’s Manual from 1973 suggest skipped filter changes. That engine was carbureted and called for API-SE oil.
I use a MityVac every 5K, usually a little less. Swap the filter every 2nd (or even 3rd) time.
Honda and Toyota suggest 10K services, so perhaps you are not missing a filter swap, rather your are simply doing short interval oil changes.
The nice thing about this is, there is little reason to wait on a service is all I gotta do is MityVac the oil and dump in the fresh stuff.
I have done an oil change on Christmas day, after getting cleaned up, It's that easy.
Used to with the OG Fram Ultras. Now, usually every oil change gets a new filter.
If you have a clean engine, probably not a big deal. For me, I change it every oil change. Nobody is wrong, just different views.
One upside is being able to do a topside oil change and not change clothes, use ramps, crawl under the car, etc. And Honda, for one, has this regimen built into its Maintenance Minder.
None of my cars have that ability. I already have to put car on a ramp, already have to take the small engine guard cover off.
It may make sense in some cars, but none of mine. I'm there anyway, so, I just change it.
Cut some filters open and see what they look like.
A properly functional gasoline engine will make less than 1 gram of stuff the filter can catch every 1,000 miles.
I have been using Fram silver can filters (Tough Guard I believe), but am considering getting Ultras or Synthetic Endurance and switching the filters every other oil change. I figure an oil filter rated for 20,000 miles should definitely be good for a year and 10,000 miles.
Yes on the bold part.
I've also read that an oil filter might actually become more effective at filtration when it is slightly clogged by particulates and the rationale made sense to me.
False ... oil filters lose efficiency as they load up and the dP increases across the media. Filters with a high ISO 4548-12 efficiency rating hold their efficiency better with use and loading then low efficiency filters.
Am I crazy?
You're not alone. I'm on my 3rd oil change on a Fram Endurance on a 2024 Toyota Rav4 Prime. At 781 miles I changed oil and filter and currently at 10971. I plan on changing out Fram Endurance closer to 20k miles with oil changes every 4k miles.
That tremor was BOF rolling over GRHS,,, kinda miss the dude.
I ve done that quite bit, if you search post i started you'll find quite a few with corresponding used oil analysis and cut filters. Particularly the Civic.
You can if you come to Canada. With the exchange rate, the cost that I pay at my Carquest is $8.04 CDN which works out to $5.75 US
No price increase at Carquest in Canada? Guess they know the US is use to the inflation train, so jack it up! :D
For the most part, engine oil filters are good for a year at least. I change out filters once a year at fall service, engine oil is changed 2-3x a year.
