- Joined
- Nov 18, 2024
- Messages
- 227
First post from new member here I'm not a real motorhead but like reading through the forums on here.
I have a 2014 V6 Honda Accord coupe with a manual transmission. The car only has 20,000 miles on it and I must say it is kind of fun to drive. I drive conservatively most of the time but the car sees redline pretty often on 2nd and 3rd gear pulls. Because I drive it pretty aggressively at times I'm sticking to 5,000 mile oil changes at which point my maintenance minder is usually at 20 or 30%. The car uses no oil between changes and runs iike a champ.
The oil change process is easy overall, but the filter is set up to where it makes a pretty big mess on the frame and also splashes some oil on the tire and rim if I'm not super careful.
I have been using Fram silver can filters (Tough Guard I believe), but am considering getting Ultras or Synthetic Endurance and switching the filters every other oil change. I figure an oil filter rated for 20,000 miles should definitely be good for a year and 10,000 miles. I've also read that an oil filter might actually become more effective at filtration when it is slightly clogged by particulates and the rationale made sense to me.
I also change the oil on my dad's 2012 CRV. The filter is super convenient on that car so I'll stick to 6K changes and silver cans for that one.
Am I crazy?
Am I crazy?
