I'm looking for a suitable oil filter for my boat engine. It's a marinized GM 3.0L L4 Carb. The Volvo part is 835440 which is an insane amount of money for basically a PH30. I had ordered PBL15313 from Amazon but am now reading all the black glue issues they are having. Fram is gone, CT doesn't carry the newer M1-111A and everything else I find recommended here doesn't seem to be available in Canada. Through some googlefu I think I found that the Napa NGF 7099 is also compatible. Definitely needs to be the stubby version of this can as the engine mounts are in the way of anything taller.
I'm going to use Pennzoil Marine 25W40 semi synthetic as the oil. I'll never reach the hour count for oil changes I'll be changing it every spring as I prep the boat for summer.
Any other Canadian available filters I should be looking at? Local CT seems to be switching to WIX from Fram but same issues as the Purolator filters?
