Euro Oil
Have a 2023 Hyundai Santa Fe. It calls for 0w30 motor oil. I know Mobil carry's it, but so does Pennzoil. Pennzoil states it is for Euro cars. Could I still use it in my Santa Fe? Even though it is NOT a European car?
Amsoil sells 0w30 non-Euro and 0w30 Euro, both SP Certs. I believe HPL does also.
Not sure if other oil bottlers sell-2 different formulations in SP.
The Pennzoil Euro 0w30 is only rated API SN. I would stick with an API SP oil if that's what Hyundai requires, just due to warranty concerns. The euro oils are also a lot thicker, which will impact fuel economy.
An API SP 5w30 would work just fine outside of extreme cold weather, and will give you a lot more options. Or, just use the Mobil 1 0W-30, which is a good oil.
Yes. All of the euro oils today should meet the performance specifications of API SP.
Thanks buddy. Just want to play it safe. THANKS AGAIN!!
No, just the usual stuff like ILSAC 6 and "The Donut" Manual says nothing European when it comes to changing oil. I just don't know whats in Euro. Oils. And hell, I don't want to lose my warranty.
Thank you for the quick response sir!!
Euro oils are about the only good thing associated with Europe, other than the views you can see if you visit it. Any engine that’s not a severe oil burner can use Euro oils safely as long as it also carries your manufacturer’s recommended approvals.
I would think euro oils would be better for oil burners - no? Aren't they typically low SAPS - or do I have this backwards?
