does Amsoil SS thicken with use?
I haven't experienced HPL SC yet but Red Line HP 0W-20 gained 0.4 centistokes after 1,800 miles. HPL Super Car also does that. Does Amsoil Signature Series behave like that too?
I like oils that do that instead of thinning.
Thank you
Thank you
Was the viscosity tested before use? there's variation in the production, so 0.4 cSt either way is not uncommon. And there's variability in testing. I would consider that the same viscosity after use.
All oils will thicken over time due to oxidation. It happens to some quicker than others depending on the formulation. If you can control the oxidation rate you can control how fast it thickens. Amsoil is one of the most oxidation resistant oils on the market.
Everything will eventually thicken with use. But a 0.4 cst change is margin of error since there's a lot of variance in testing. You can test the same sample 10 times and every single one will be a little different.
Another instance of technical decision making on what is likely wholly insignificant data.
Much like "I put oil X in my car and got a .3 MPG improvement!"
Why not buy a thicker oil to begin with instead of hoping that an oil will get thicker in a good way?
Thank you
I picked up a Mobil 1 0W-40 from Walmart shelf, shook it, it made a weird thicky sound so I put it back. My lil Jeep is not a Ram TRX 😆
Try Mobil 1. It's not as thick! lol
So you went from 25 to 40 and skipped 30? I'm guessing because it's harder to find 0W-30. I don't see much on shelves either.
Does your winter temperature range require a 0W oil?
There are lots of good 5W-30s out there.
Nope, I live in Seattle. 35 - 45 degrees most days in winter. Do you think PUP 5W-30 will flow fast and nice at 35 degrees? Or Mobil 1 Truck and SUV 5W-30?
We live in the same area!
Even a 10W will do.
I use a good chunk of M1 EP 10W-30 because all my cars like it. Can't get it to burn in any of my cars old or new!
Yes. Every oil does this due to oxidative thickening and soot/contamination loading. Oils that show a lower viscosity in UOA are doing this too. If an oil starts at 10.5 cSt and shows 10.0 cSt after 5k miles and no dilution present, it likely sheared down to 9.5 cSt (or lower) before thickening back to 10.0 cSt. Since HPL's oils don't shear, you only see the thickening.
