Understood, however I don’t believe new oil will loosen contaminants from a filter that has trapped said contaminants already. New oil or old oil, the filter catches particles of the same size. It can be easily debated that a filter with some miles filters better than a new one. If new oil at any one particular change lets loose enough sludge to cause an engine a problem, well, there’s more of a problem going on than anything were referring to with this discussion and it’s not a filter issue.
If the filter is good for 20,000 miles, changing at 10,000 miles simply means you don’t believe that filter is up to what the manufacturer says. Just like changing the oil in the car at 3000 and 4000 miles when the manufacturer recommends an oil change interval double that. Up to every individual but that’s just saying manufactures are not to be believed.
