Originally Posted By: Drew99GT
Originally Posted By: Jaymus
I think it would work with a 30 or 40 weight.
http://www.allpar.com/mopar/new-mopar-hemi.html It's not just oil pressure. You can think all you want, but 5w-20 is required for the CDS to work properly.
Yet again, more proof that it's probably best to follow the manufacturer speced oil and not "think" you know better.
It says nowhere in that article that it is required. I see where it says "May not work", but no "required to work". You can use any oil you want as long as your pressure doesn't exceed 75psi when warm to allow the cylinder deactivation to work. A 5W-20 is not required like you think. You actually think a 5W-30 will destroy the engine? Of course not. You think a 5W-30 won't allow the cylinder deactivation to work? Nope, it will still work.
Again, "minimum and maximum oil pressure limits for cylinder deactivation and reactivation were established at 75 psi and 18 psi". It does not 'know' if you have something other than a 5W-20 in there. It just knows oil pressure, and goes by that. A 5W-20 would allow the C.D. to come into effect first, but does not mean a 30 or 40 weight won't work. A 5W-20 when cold is thicker than a 20W-50 when warmed up. So, why doesn't that 'destroy' or 'damage' the engine during the first 10+ minutes of usage? No need to try and get technical, it's all about the psi.
