Originally Posted By: Gary Allan
Quote:
I have seen engines that were plain old worn out before. No oil pressure at idle due to excessive bearing clearances, and burning oil badly when lifting throttle. No other issues besides too many miles. Engines do wear out.
Sure they do. It's just the last time I saw one was my old bosses 1961 Ford Falcon. If you put on the brakes too hard, the oil light flashed. At a certain rpm, it was like you turned on an afterburner due to enough oil pressure.
That was in 1976.
Now, again, I've seen them neglected and destroyed. I've yet to see a tired engine that was properly maintained outside of some bracket racer that's refreshing every three years anyway.
Quote:
You are thinking in absolutes. Just because 20wts aren't sending cars to the junkyard with a rod through the pan doesn't mean they wouldn't be in better shape at the same mileage with a heavier oil.
While I agree with the concept (that "end of life" doesn't equate to health) we have to remember, as I stated before, that our standard 5w30 was shearing to a 20 grade anyway. If you've been using conventional 5w30 oil from the day it became widely adopted ..through the recent past, AND you ran it for any length of time, ..then you too have been using a 20 grade. You just didn't know it.
Quote:
I'm very confident I have something to gain by the (true) 30wt I'm running but I can't find a single positive of running the recommended 5w-20 in my climate.
I don't believe that I've stated that they're for everyone. For engines that are spec'd for it ..outside of design flaws and neglect, I would welcome evidence that there's any degradation of utility ..or higher frequency of service because of the use of 5w-20 oil.
While you can see no advantage to using them, I don't think you can produce a legit documented liability either
Gary, your points are understood and I agree for the most part.
When I mentioned a 30wt, I'm talking about a straight 30 (ACD), not something that will sheer down in a few miles.
I hope in a few years, if BITOG is still around I will have teardown results of my TL running ACD 30wt all it's life and by then I hope there will be enough worn engines to compare to. I will either say I told you so or admit I've been wrong all these years.
I do believe if wear with 5w-20 was exactly the same as a 10w30, the same engine would be spec'd for 5w-20 outside of the US but usually they're not.
