- Joined
- May 3, 2023
- Messages
- 18
I've got a 2019 Honda HRV with the R18z 1.8L naturally aspirated engine. I've found both the US and UK owners manuals and have included snippets of the oil weight recommendations of each. The US manual calls for 0W-20 and only 0W-20. The UK manual states that 0W-20, 0W-30, and 5W-30 can be used, depending on ambient temperature. My question is whether or not the US engine and the UK engine are identical? If so, is there any reason I can't use a 30 weight oil when inside of the correct ambient temp parameters? I know that many state that 0W-20 oils ore only recommended by manufacturers due to CAFE. I'd only feel comfortable using a 30 weight if I could be reasonably certain that both manuals are referencing the same exact engine.
