Originally Posted By: Drew99GT
The only way you could prove to me that 5w-20 IN THAT ENGINE produced more wear, would be to run 5w-20 of the same brand for several consecutive intervals, and run 5w-30 of the same brand for several consecutive intervals, after the engine was fully broken in.
If you've learned anything about UOA, the conclusions you've drawn, Jaymus, are meaningless, especially since the PP 5w-20 was used from 10,000 miles to 15,000 miles when the engine was still breaking in. The silicon numbers are indicative of sealant still leaching during break in.
We repeatedly see spikes in wear from simply changing brand of oil, especially with synthetic oil, of the same viscosity.
You shouldn't draw any conclusions from two back to back UOA of different brands and different viscosities, when the engine is still breaking in.
+1
Whenever you introduce a oil with a new chemical make up into the crankcase, the engine will have slightly odd wear. Once you use the oil 2-3 OCIs, the engine will put out true wear numbers.
That, and in this case the engine was going through break in.
