We've got 9 Fords within my (admittedly large) family and all have been good cars, several have been absolutely great cars, none have been bad. None are particularly new either, most fall in the 2010 to 2017 range so that makes me wonder if things really started to turn the wrong direction the last several years?
They have introduced a slew of new products very quickly, amidst a pandemic no less that can't be helping.
If I were to buy a new domestic today Ford would still be at the top of my list by far, but I'd do some research first.
So far, there have been a total of eight recalls issued for the 2016 Ford Fusion. These recalls are as follows:
NHTSA Recall ID: 16V875000
Recall Date: 10/01/2015 – Affected Component: Fuel Tank
In 2015, Ford issued the first recall for the newly released 2016 Ford Fusion, citing a faulty fuel tank as the reason. Per the recall, certain 2016 Fusion models may have been outfitted with a fuel tank whose walls were insufficiently thick. In the event of a crash, these faulty fuel tanks are prone to breaking, dramatically increasing the risk of an explosion or fire due to fuel leaking into other components of the vehicle. In order to resolve this issue, Ford has offered to replace the fuel tanks free of charge on all affected models.
NHTSA Recall ID: 16V250000
Recall Date: 04/27/2016 – Affected Component: Front Seat Belt
In 2016, a recall was issued for certain 2016 Ford Fusion models that had been manufactured from March 10, 2016 to March 26, 2016 after Ford discovered that these models may have been equipped with a front driver seat track assembly’s rear riser that had not been properly welded to the seat track rail. In the event of a crash, the welds on affected models could break, causing the seatbelt to fail to restrain the vehicle’s driver. In order to resolve this issue, Ford has offered to replace the front seat track rail free of charge on all affected models.
Recall Date: 12/05/2016 – Affected Component: Front Seat Belt
Less than a year after issuing the first recall regarding the 2016 Ford Fusion’s front seat belt, Ford was forced to issue another recall for the 2016 Fusion due to the same component. Ford discovered that heat from the deployment of the seat belt’s pretensioner may cause the 2016 Fusion’s front seat belt anchor cable to fail in the event of a crash. If this component fails, the driver would not be properly restrained by their seatbelt in the event of a crash. In order to resolve this issue, Ford has offered to apply a protective coating to the seat belt cable free of charge on all affected models.
NHTSA Recall ID: 18V167000
Recall Date: 03/12/2018 – Affected Component: Steering Wheel
In 2018, Ford issued a recall on certain 2014-2018 Ford Fusion models, citing a faulty steering wheel as the cause. On affected models, the steering wheel’s restraining bolt may loosen over time, resulting in the possibility of the steering wheel coming detached while the vehicle is in operation and causing a dangerous loss of control. In order to resolve this issue, Ford has offered to replace the steering wheel restraining bolt with a longer bolt free of charge on all affected models.
Recall Date: 07/16/2018 – Affected Component: Transmission
In 2018, Ford issued a recall on certain 2013-2016 Ford fusion models that had been equipped with a six-speed automatic transmission. On affected models, Ford discovered that the bushing attaching the transmission shifter cable to the transmission is prone to degrading over time, resulting in the possibility that the shifter cable comes detached from the transmission. In the event that this happens, the vehicle may show that it has been placed in park without actually ever shifting into park, potentially leading to a rollaway. In order to resolve this issue, Ford has offered to replace the shifter cable bushing free of charge on all affected models.
NHTSA Recall ID: 19V362000
Recall Date: 05/13/2019 – Affected Component: Transmission
In 2019, Ford was forced to issue another recall on certain 2013-2016 Fusion models that is almost identical to the previous recall issued in July 2018, this time for certain 2013-2016 Ford Fusion models that had been equipped with a 2.5L engine. As with the previous recall, Ford discovered that the bushing attaching the transmission shifter cable to the transmission is prone to degrading over time, resulting in the possibility that the shifter cable comes detached from the transmission.
NHTSA Recall ID: 19V632000
Recall Date: 08/29/2019 – Affected Component: Power Steering
In 2019, Ford issued a recall for certain 2013-2016 Ford Fusion models that were originally sold or currently registered in Connecticut, Delaware, the District of Columbia, Illinois, Indiana, Iowa, Maine, Maryland, Massachusetts, Michigan, Minnesota, Missouri, New Hampshire, New Jersey, New York, Ohio, Pennsylvania, Rhode Island, Vermont, West Virginia, and Wisconsin. On affected models, road salt and/or other factors may corrode the vehicle’s electric power steering gear motor attachment bolts, leading to a loss of power steering. If this loss of power steering occurs while the vehicle is in operation it will make it much more difficult to control and increase the risk of a crash. In order to resolve this issue, Ford has offered to replace the steering gear motor bolts and apply a wax sealer free of charge on all affected models.
NHTSA Recall ID: 20V177000
Recall Date: 08/29/2019 – Affected Component: Door Latches
In 2020, Ford issued a recall on certain 2014-2016 Ford Fusion models, citing faulty door latches that may fail while the vehicle is in operation. This recall specifically affects 2014-2016 Fusion models that were originally sold or ever registered in Alabama, Arkansas, Arizona, California, Florida, Georgia, Hawaii, Louisiana, Mississippi, New Mexico, Nevada, Oklahoma, Oregon, South Carolina, Texas, Utah, Washington, Puerto Rico, American Samoa, Guam, the Northern Mariana Islands (Saipan), and the U.S. Virgin Islands. On affected models, a component within the door latch may break, potentially causing the door to come open while the vehicle is in operation. In order to resolve this issue, Ford has offered to replace the door latches free of charge on all affected models.
