Right on**SEE POST #19**
With a solid lifter there inherently is a gap between the lifter/cam - otherwise your valve wouldn't close fully - and there is more with age. So if you don't have good oil flow at the top end the gap causes a click as it cycles. With good oil flow there is enough lubricant between the parts to deaden the sound of the lack of continuous contact between the parts.The noise is not coming from a solid lifter due to low oil pressure, why would it?
Well it's a collection of grit rather than chunks. Chunk by definition wouldn't get passed the screen right?It's a bit funny to me that there are folks using (I've used it too in multiple cars!) the HPL EC have shown pics of some solid-chunks of crud in their filter but are worried about a flush product doing the same thing. A can of LM engine flush isn't going to "dislodge chunks" and ruin the engine idling it for 15 minutes. I vote as I said above...use the LM Engine Flush, drain, fill with whatever oil you want adding a bottle of the HPL EC, go 2-3K, drain, then go with a normal oil change schedule with whatever oil you like to use.
You said..With a solid lifter there inherently is a gap between the lifter/cam - otherwise your valve wouldn't close fully - and there is more with age. So if you don't have good oil flow at the top end the gap causes a click as it cycles. With good oil flow there is enough lubricant between the parts to deaden the sound of the lack of continuous contact between the parts.
What you are claiming will result in a cam destroying event in minutes. Noise from solid lifters/lash adjusters is a sign of parts needing adjustment and nothing to do with oil pressure. You are describing hydraulic lifters not solids, if what you describe did happen (no oil film) on parts the bearings would also be dry and the engine destroying itself in short order.VQ's have solid lifters, so if there not clicking while warm at idle its a good sign of decent oil pressure.
The point was simply that folks around here lose their minds when you say "flush" (or solid additives like MoS2) b/c they are wrorried about solids but then rejoice when you get solids in your filter using HPL EC. It's hilarious to me. The difference with the HPL EC is that it's just a straight-grade oil with a forumation that promotes cleaning (esters) so different than a solvent-based product like the LM Engine Flush.Well it's a collection of grit rather than chunks. Chunk by definition wouldn't get passed the screen right?
In any case the EC is much milder than their standard oils anyways. LM engine flush is even more mild if not ineffective on hard deposits. Both probably work dissolving goopy sludge.
The difference is that EC is to be used on a 2,000 mile interval vs 10-20 min idle from flush products like LM. The concern is the speed of the cleaning where the release of a lot of material deposits could cause a problem before they were fully dissolved by the flush product.The point was simply that folks around here lose their minds when you say "flush" (or solid additives like MoS2) b/c they are wrorried about solids but then rejoice when you get solids in your filter using HPL EC. It's hilarious to me. The difference with the HPL EC is that it's just a straight-grade oil with a forumation that promotes cleaning (esters) so different than a solvent-based product like the LM Engine Flush.
https://www.mobil.com/en/lubricants...motor-oil/mobil-1-keeps-engines-running-cleanAquired 2014 Nissan Altima 3.5 V6 with 211k for a Song. Maybe? So I decided what the hell, and got it. I did see the sludge inside the oil cap before I got it. I changed the oil once with a Auto Zone filter and put some Walmart full Sys GDI 5/30 in it. So what should I do? I oil sludgepour in treatment? Or should I just try a few oil chnages and filter with Mobile 1 High mileage, or the Penn Ultra Platinum? Considering droping the pan to clean and screen maybe.
The Pics actually looks worst than they are, if that even makes any sense being it has sludge. I have seen way worst though, I mean way worst. I dont know the story or history other than it looks like it does for a reason, and/or not. The sludge is semi- kinda harden a bit, some of it. What would you guys do? I mean to try and help it some? Thanks.
BTW: I has no other engine issue (not yet), no smoke, no leaks, runs strong, quite and smooth like a top, with Sludge. Drive about 275 total miles and checked, no oil comsumption..... yet. I'll try to take some more pics to post up.View attachment 147812View attachment 147813
Yes but your engines never get dirty.Nothing scary about the LM product (or the HPL product), I've used the LM flush product many times in multiple vehicles....this site is so overly paranoid about these things without any basis that I've ever seen. Many folks use these products without issue. Good luck with the car!
I'd say that W8 was questionable and likely had quite a bit of crud in it when I used the LM product (twice...2x cans each time).Yes but your engines never get dirty.
Generally the older advice and it is sound advice is that it's better to do it over time. It will gradually clear up on it's on as you do your regular oil changes on time, maybe 3k instead of 5k depending on the type of driving you do.
Generally you could replace 1 qt or 1/2 a qt of oil the next oil change and run something like MMO or similar products for 100-200 miles and drain it and fill it. Personally? I would just use any of the high quality oils available off the shelf and run them for a shorter interval for a few OCI's and take a look back in there. The photo's don't indicate that it's terrible and it doesn't appear to be impacting the performance of the car - let the oil do the work.
Do not run MMO. There are zero benefits.
Just a update. I did a oil change with M1 Extended Performance. Not HM Ext Performance.https://www.mobil.com/en/lubricants...motor-oil/mobil-1-keeps-engines-running-clean
M1 High Mileage all the way - - - go slow to clean that junk out.
Change oil and filter early - 2-3k tops.
Then change at 5k for each change after.
Ok good stuff. So I am just a basic DIY home gargae oil change guy.
Now some dummy questions? What is MMO?
Is the Mobile 1 High Mileage a good one to use to help some?
I called the guy who got the car for 2 weeks then Sold it to me. He now just a few mins ago tells me he did a Flush with 1/2 can of Motor Medic Motor Flush then changed the oil and filter just 300 miles ago. That worrys me. Said he did because he took it to a Nissan Dealer and they told him it was heavyly sludged. I'm take you guy's advise here. I thought the engine would be ok myself too.
1 more pic attached. View attachment 147818
Is it specifically the M1 Ext Per High Mileage that I need to use that cleans the best?
