nobody is noticing that those deposits are on the side that is above exhaust manifold!!!
The plastic guides broke, so he replaced them. Yes he dropped the oil pan and got all of the pieces out.quote:
And why a new timing chain at 88000? Its not even thought about until 120,000 miles for that engine. Was the chain slapping due to broken plastic guides? If so, were the pieces found, or just left in the engine or pan?
THe truck was driven very little in its first 12 years. It was mostly driven short trips.quote:
It also looks like the oil change interval was over extended for the driveing as it most reseambles an engine used for all short trips. I would do a UOA and look for fuel diloution as well. This could be caused by a bad cold start injector as well.
Yes it was. The previous owner is a mechanical engineer. I know he likes to wrench as a hobby. There was no oil pump failure or anything like that.quote:
If the guy replaced the chain,guides and oil pump it was not for preventive measures at all!
I knew we could find someonequote:
GA, my Chrysler "averaged" a little under 4,000 miles/year for 34 years, and the FORD above was at 3200 miles/year. In truth, both sat out a few years, and then ran over 15,000 miles in some years, or less in others. ARX WILL make a difference, I couldn't agree more.
YEah, I carfax'ed it before I bought it..quote:
Im courious if you can get a car fax report.
