Hello BITOG members, long time reader first time posting. My friend who did not get her license until her mid 20’s/just informed me that she hasn’t changed the oil in close to 3 years, but that she has topped it off several times. According to the sticker on her window it has been 25k+ miles since it was last changed. To make matters worse, much of her driving is short 1-3 mile trips that don’t reach operating temperature.
2018 Toyota Corolla 1.8L, OEM specs 0w20 GF-5 oil. Only 65,000 on the odometer!
I am going to do an oil change on it soon using Mobil 1 Extended Performance 0w20. I will keep an oil sample of the old stuff to send to blackstone just for fun as well as cut open and examine the oil filter and post results. Besides just fresh oil, I feel a need to do some sort of cleaning after that amount of neglect, but don’t want to knock any deposits loose and clog up oil passages/screens. Im also not going to be able to constantly monitor her vehicle. My question is, how should I now proceed to remove the contamination left behind?
A.) Some solvent flush (LM engine flush or other?) added to old oil and drain. Refill with new Mobil 1 Extended Performance oil and run a shortened 3k OCI
B.) no solvent flush, drain and fill with 1/5 oil cleaning additive like HPL Engine Cleaner 30/MMO/SeaFoam/Auto-RX or others and use something like T6 Multi-vehicle 5w30 (as the additive will likely dilute the viscosity closer to 0w20) and 3k OCI.
C.) Drain old oil, fill the whole thing to the top with diesel fuel (or something else?) let it sit a day and drain. Refill with cheap rinse oil and filter - run for 30 minutes - drain. Fill with Mobil 1 Extended Performance 0w20 and run 3k OCI.
D.) No special flushes or additives, Fill with Mobil 1 Extended Performance 0w20 and run 3k OCI.
E.) Some combination of treatments listed (or not listed) above.
I haven’t evaluated the engine yet to see how much sludge exists, I will do my best to document and update this post. I wouldn’t worry about doing any of these options on my older Toyota 2UZ-FE engine, but I am a little cautious on this newer 0w20 vehicle that has been running the same oil for almost half its life. Thanks for your insight, hoping for someone with experience in a similar vehicle
