Obligatory:Sounds like they should have just revived the 2JZ and given in dual injection. Hope you don’t have issues with yours, it’s a shame that Toyota seems to have lost its way.
Gives it more Diddy up and go …Obligatory:
I'd only swap in Diddy into a beater.Gives it more Diddy up and go …![]()
It makes me wonder though, how many less problems would there be (specifically with the 10 speed Ford's) if they didn't choose to borderline overheat them during normal usage.
Even in 2005 they were doing stuff similar to this (for emissions I assume)...i had to tell my coworker not to stop turning off the AC when I'm not in the truck... because he'll get too cold but leave the engine running and it does not turn on cooling fans until 230f unless the AC or defrost is active then it keeps it under 200. It drives me nuts.
I certainly keep a VERY close eye on mine now when I tow (Actually all the time). My maximum comfortable temp is 210. It'll spike up there but cool down quickly.Temperature has been brought up with the 10R80 CDF Drum sleeve walking, Not sure about the validity though.
What does it explain? Wasn't he the Head of Design for the previous gen?The head of the Tundra development came from Chrysler. Now he is the EVP for all North America development. This explains a lot in my book.
Before I commented I searched the internet and found a failed LS engine on the first page of threads, so there are failures but like I said its a halo vehicle.So, this engine has reportedly also been used in the Lexus LS since 2017.
If it’s a design problem (insufficient oiling), then why haven’t there been any reported problems with the LS?
I realize that the engines between the LS and the Tundra/LC may not be identical. But they’re close enough that I doubt there would be major bottom end design differences.
I’m not sure I would jump to the conclusion that it’s a design fault and that Toyota is being deceptive.
Toyota hasn’t gotten to where they are by operating in that manner.
Probably there is, but LS is low volume seller. Don’t forget that Toyota successfully avoided recall of problematic transmissions in 2017. However, customers didn’t avoid failed transmissions. They just quietly resolved problem for 2018 and left customers of 2017 Highlander and Sienna AWD models hanging out dry.So, this engine has reportedly also been used in the Lexus LS since 2017.
