You can definitely see that they are targeting BMW/inspired by BMW with many of the choices, particularly in the interior. Looks like a really good effort by Mazda!
Not sure if it more aligns with the X5 or X3, but here's the X5 PHEV in comparison:
Mazda has had a lot of issues with newer things. Im interested, but will hold off until a while.Even with a company known for great quality, the old saying about avoiding the first years of a generation of vehicles still is good advice. If I were in the market to but one, I would wait unitl the 3rd of 4th year, and also read any user complaints on any forums for that vehicle before getting one.
My prime's awd sucked for anything but crawling speeds.It is great that Mazda depends on the mechanical way to improve the handling rather than electrical one, which gives more reliability and consistency.
https://www.autoevolution.com/pdf/n...mes-as-phev-and-gas-or-diesel-mhev-183354.pdf
it is going to be an 8 speed dual clutch regardless of what you think.
It sounds like a conventional automatic but they've replaced the torque converter with a clutch system, perhaps due to the use of the integrated electric motor/generator.Okay, after reading into that press release a bit more I got confused on the transmission. On page 27 it calls it a 8 speed transmission but on page 31 it says it’s a 8 speed without a torque converter. It doesn’t specifically say it’s a dual clutch either. I wonder if this is the Toyota transmission or a version of it?
From the press brief:
Mazda’s new eight-speed automatic transmission offers drivers smooth and responsive gear shifting with clear, smooth gear steps and a wide range, achieving the right balance of dynamic and environmental performance.
The new transmission shifts gears in the same manner as a torque converter transmission – via planetary gears and multi-plate clutches – but it does not have an hydraulic converter as an input clutch, rather, a multi-plate clutch as well as an integrated electric motor/generator.
By replacing the torque converter with a clutch, the torque of the engine and motor is transmitted directly, with fast and rhythmic shifting much like a manual transmission.
In addition, the clutch’s friction transmission and cooling functions have been evolved to achieve smooth starting and high efficiency.
The Mazda CX-60 e-Skyactiv PHEV’s hybrid powertrain allows for the independent power mixing of the petrol engine and electric motor, and the new transmission helps to implement this smoothly at all speeds.
The compact design of Mazda’s unique eight-speed transmission and the optimal layout of the entire powertrain effects a smaller transmission tunnel space, minimising the impact on the pedal box space and allowing for an ideal driving position.
An electrified version is available to deliver a virtually “off the shelf” parallel hybrid (at least, in terms of transmissions), equipped with an electric motor in place of the torque converter, and occupying virtually the same package space.
If you watch the X5 video I posted, they show how the electric system works. It is flawless and likely functions similarly to what you describe. I've driven one, you have no perception of which is operating unless you are listening for the engine (which is difficult to hear) and the transition between gas/electric is imperceptible.With a decent size electric motor they could use the electric motor to carry the vast majority of the drive load / (braking load durind engine braking) by using computer control of both the engine and the electric motor / generator and essentially have very little to no load on the clutch or clutches doing any shifts and then synchronize the speed of the petrol motor to the transmission side of the clutch that was to next be engaged before engaging the clutch. This would essentially eliminate any load on the clutch during engagement or during disengagement. This would drastically increase the life expectancy of any clutch in such a system. This would also allow them to use dry clutches, that are more efficient then wet clutches that lose efficiency due to oil drag interactions between the clutch and the surrounding housing. All-in-all if properly thought out and executed a system that takes advantage of having an electric motor to carry the load before the clutch is used could be a smooth and long-lived very efficient drivetrain. Throw in regenerative braking and plug-in Electric efficiency low cost of providing power to the vehicle especially for short trips, and this could be a very nice vehicle to own after all the bugs are worked out.
And electric motors can be designed to handle more than their continuous rated power for brief periods of time with no damage to them.
This means that even though the electric motor may have a continuous output rating of less than the amount the petroleum powered motor is rated for that the electric motor could be designed to handle 100% of the power demand during clutch usage.
It sounds to me to be similar to the ZF design I posted with the electric motor being where the TC would have been previously.Great discussion here.
Referring back to the press release that @stormgol linked to, it reads to me that the PHEV has a electric motor mounted between the engine and transmission plus the transmission has its own electric motor/generator.
From the brief:
“The new transmission shifts gears in the same manner as a torque converter transmission – via planetary gears and multi-plate clutches – but it does not have an hydraulic converter as an input clutch, rather, a multi-plate clutch as well as an integrated electric motor/generator.
The Mazda CX-60 e-Skyactiv PHEV’s hybrid powertrain allows for the independent power mixing of the petrol engine and electric motor, and the new transmission helps to implement this smoothly at all speeds.”
So this seems to fall in line with the discussion here.
Another tidbit, the fuel economy is rated at 1.5L/100km. Converted to US measuring that rounds to 156mpg. Impressive fuel economy for this size and weight of automobile.
