I believe wix updated the 57045xp to wl10255xp gm spec 22psi bypass,Use the taller 57045XP in my GM 2.0T and GM 3.6.![]()
LoL ... lots of ticking 5.0L Coyotes regardless of what oil filter is used. What you're experiencing is something different than the typewriter tick it seems - the oil filter has no effect on the typewriter tick. Could be something else, like the cam phasers. Leave the filter on that seems to "cure" it and see what happens down the road.Should of changed oil filter![]()
Could be phasers but I doubt it as I replaced phasers on my 2009 f150 5.4 3v, that had a bad warm idle knock, I took apart the old phasers and was surprised how many small moving parts and springs were in there and very small oil passages, not sure if the 5.0 has similar phasers.LoL ... lots of ticking 5.0L Coyotes regardless of what oil filter is used. What you're experiencing is something different than the typewriter tick is seems. Could be something else, like the cam phasers.
The taller wix 57045xp provided a very quite tic free 5.0, this filter is spec for gm and chrysler engines, the short wix 57502xp is spec for ford, difference between the 2 is obviously height and bypass psi, 57502xp has a 22psi bypass, 57045xp has 12psi, I was concerned about that and found out that wix updated the 57045xp to wl10255xp with a 22psi bypass, I could not get a wl10255xp locally but managed to get a napa npl 100255 I believe is made by wix and is the same filter, I spun that filter on and same results quite 5.0. The butt dyno feels better throttle response with less pedal travel to achieve acceleratoration. The fl500s, fl2121b12, champ 500xl and fram xg10575 all provided warm idle knock and tic. Oil I have in the pan is 5w20 and used the same oil for all these tests.
Oh man, sorry to hear that, mines quiet, didn't help at all ?I was intrigued by this post and since I have experienced the typewriter tick since new and was due for an oil change I figured I would give it a go. Unfortunately, the Napa brand GM version filter you described with the higher bypass pressure made zero difference for me.
Lots of people with the Coyote that have the typewriter tick have success with adding as little as 1/2 bottle (150 ml) of Liqui-Moly Cera Tec. It makes the tick dissapear almost instantly after adding it to the oil. YMMVNo, unfortunately it did not. I have also experimented with different oils from 5w20 - 15w40, now at 52k miles and nothing I have tried makes a difference.
Maybe try the new motorcraft fl2121b12 oil filter, didn't work for me, I have gone threw various filters and oil weights, not just with this 5.0 but previous truck with 5.4 3v, just to be clear, the tic and light knock that I have experienced has been very minor and did not impact performance, just pisses me off, hate tick knock type noises coming from engines. With all the tests I have done with the various filters and engine weights ie, 0w20, 5w20,5w30,0w40,5w40, seemed to have an impact on noise and performance, thicker oil seemed to make the 5.4 and 5.0 sluggish, I tried 5w30 with fl500s on 5.0 and the tic was noticeably louder. I have read many posts regarding the tic coming after first oil change from brand new trucks and mustangs, not sure what oil they use from the factory but we know it's not a fl500s oil filter, it's a fomoco filter that kind of looks like a wixNo, unfortunately it did not. I have also experimented with different oils from 5w20 - 15w40, now at 52k miles and nothing I have tried makes a difference.
You can't upload video files to this chat board.How do you unload video, says file to large
A lot of guys with the Coyote don't have the tick, nor does it show up right after an oil change (regardless of the oil or filter used) like others see. It's not the oil filer, it's more the oil and the formed tribofilm on parts because adding 150 ml of Ceratec makes the tick go away almost instantly. It changes the friction level between moving parts, and the engines that are prone to tick are for some mechanical reason sensitive to the friction level of the oil.I have read many posts regarding the tic coming after first oil change from brand new trucks and mustangs, not sure what oil they use from the factory but we know it's not a fl500s oil filter, it's a fomoco filter that kind of looks like a wix
Go to a free video hosting site and then you can paste the URL here...How do you unload video, says file to large
