How did you like that?had a diesel Tempo. (Don't ask ...)
I wonder if the OEM filters at the time had different efficiency … the one being on the "bypass" circuit being higher efficiency? Back then, it would probably be nearly impossible to get that kind of infoDon't believe me? Look up the application on a filter site
Here are the Wix filters;
51324... 2/20=6/20 with 9-11 gpm flow (111mm tall)
51839... 2/20=6/20 with 9-11 gpm flow (96mm tall)
Why the different filters? I expect it's because the shorter one (which was mounted base-end up) had a VERY tight area to fit and the longer (nearly identical filter) wouldn't fit. Why they didn't just spec two of the shorter filters instead of one of each size is beyond me. I mean ... why have one part to stock when you can double the PITB factor, right?
The point is that FF filter can be used as a makeshift BP filter if you greatly reduce the flow rate.
However, I don't believe that the effect would be nearly as good as a more typical BP filter element (aka Amsoil BP filters, FS2500, etc ...).
From what I've heard, engines using this type of thermostat for oil coolers will still have slower oil warm up in cold weather because it does not completely cut off the flow to the oil cooler.A critical piece of data I’m missing though is whether the thermostatic oil adapter sends ALL oil to the loop or just SOME of it. Since it’s intended for cooling primarily,I can see why they might not send all the oil to the cooler.
For the GR86 in particular, you don't want to add much restriction, since those engines struggle to maintain good oil pressure at high rpm in the first place when the oil gets hot. Builders of those engines will go through the effort of drilling out or porting certain parts of the timing cover or block connections to pick up a few extra psi at the crankshaft.I’m loathe to add more restriction between oil pump output and engine because the oil pump will be riding the regulator most of the time. Any additional restriction once on the regulator causes more oil to go into bypass and reduce actual oil flow through the engine.
Amazing fuel economy I bet.How did you like that?
If the left gauge is the one on a main gallery feeding the crankshaft (also located after the filter), then the approx 1 bar (1 bar = 14.5 PSI) pressure drop between just after the filter and that gallery location could be due to a restriction in that flow path even though it's a "main gallery". Or maybe the flow split-off somewhere before getting to that pressure point (?). Would have to see a schematic of that engine's oiling system to get a better idea.So here's an idea for the GR86, but something similar should work on other engines. The engine has two common points for measuring oil pressure: the oil pressure switch just downstream of the oil filter, and a connection at the top of the block that taps into the crankshaft gallery. There's a substantial difference in oil pressure between these two points at higher rpm, as seen here.
In the photo above, the main gallery pressure is 4.5 bars (65 PSI) at 6000 RPM with 10W-40 at 90C. Is this really causing a lack of lubrication on these engines? What's the proof of that (smoked bearings?), or are "racers" just wanting more oil pressure for the sake of having more oil pressure?For the GR86 in particular, you don't want to add much restriction, since those engines struggle to maintain good oil pressure at high rpm in the first place when the oil gets hot. Builders of those engines will go through the effort of drilling out or porting certain parts of the timing cover or block connections to pick up a few extra psi at the crankshaft.
I had to ask, as we were instructed not to ask.Amazing fuel economy I bet.
Here's a diagram. The flow does split off to one of the heads just after the oil filter, near the OEM pressure switch location. Point 12 would be where the crankshaft gallery pressure sensor would be located. Point 14 is the most obvious restriction, since the hole in the block is smaller than the piping on either side, introducing sharp-edged restrictions down to 11.5 mm diameter.If the left gauge is the one on a main gallery feeding the crankshaft (also located after the filter), then the approx 1 bar (1 bar = 14.5 PSI) pressure drop between just after the filter and that gallery location could be due to a restriction in that flow path even though it's a "main gallery". Or maybe the flow split-off somewhere before getting to that pressure point (?). Would have to see a schematic of that engine's oiling system to get a better idea.
The recommended grade is 0W-20, and the oil can get a lot hotter than 90C. Rod bearing failures have been pretty common. Here's an example of how oil temperature/viscosity can affect oil pressure on the FA20 engine. Measurements were taken at the crankshaft gallery.In the photo above, the main gallery pressure is 4.5 bars (65 PSI) with 10W-40 at 90C. Is this really causing a lack of lubrication on these engines? What's the proof of that (smoked bearings?), or are "racers" just wanting more oil pressure for the sake of having more oil pressure?
Fuel mileage was great. And they were very reliable.How did you like that?
I think it is cool. It was a machine or as Johnny Cash might say, a moshine.Fuel mileage was great. And they were very reliable.
But they were s-l-o-o-o-o-o-o-o-o-o-w-w-w-w-w-w-w-w-w-w to accelerate.
And man, were they noisy at idle, at redline and everywhere in between.
There were one-year trial lease vehicles; an attempt by Ford to test the marketplace. Didn't last long, as you would expect.
Not that I recall, but I wasn't really into Beta data at the time and BITOG didn't exist then.I wonder if the OEM filters at the time had different efficiency … the one being on the "bypass" circuit being higher efficiency? Back then, it would probably be nearly impossible to get that kind of info
IIRC, the BP filter was done every other FF change??? It's been almost 40 years ago ...Did the OM say anything special about those filters and anything specific about changing them, like different change intervals, etc?
Yep, sure do. I wonder how much of an EPA MPG impact that would have today if people weren't trying to travel at 90 on the interstate. My guess is MPGs would increase dramatically.Remember, the speed limits in most places were 55mph back then.
Thanks ... that gives a decent layout of the oiling system. I'm wondering if point 14 was a purposeful flow restriction "orifice" placed there to provide some flow control to the journal bearings, and to help balance the flow in the oiling system as a whole. When point 14 is drilled out, how does the dP between point 15 right after the filter and point 12 compare? And how does it change the Pressure vs RPM of different oils as graphed in the chart below?Here's a diagram. The flow does split off to one of the heads just after the oil filter, near the OEM pressure switch location. Point 12 would be where the crankshaft gallery pressure sensor would be located. Point 14 is the most obvious restriction, since the hole in the block is smaller than the piping on either side, introducing sharp-edged restrictions down to 11.5 mm diameter.
This hole is often drilled out to match the diameter of the piping on either side when an engine is rebuilt after it spins a rod bearing.
Yeah, the RPM vs Pressure curves are a bit puzzling. For instance, the 0W-20 @ 185F curve is right in there with the other 3 lower curves up to 4000 RPM, so that means the viscosity is probably pretty close for all 4 of those oils, so it seems they would all track each other pretty close out to 7000 RPM, but the 0W-20 @ 185F keeps climbing while the other 3 roll-off after 4000 RPM. As above, it would have also been good info if both points 15 and 12 were measured to help give a more complete picture. It could be that the lower pressure at point 12 at higher RPM with the oils that roll-off after 4000 RPM has something to do with the journal bearing side leakage and how the oils were shearing at higher RPM. If the pressure at point 15 didn't roll-over like at point 12 over the RPM range, then that could give some good info to explain the phenomena, and could give information to determine of the oil pump was falling on it's face with certain hotter and thinner oils in those conditions.The recommended grade is 0W-20, and the oil can get a lot hotter than 90C. Rod bearing failures have been pretty common. Here's an example of how oil temperature/viscosity can affect oil pressure on the FA20 engine. Measurements were taken at the crankshaft gallery.
With thin oil, the oil pressure is lower at 7,000 rpm than it is at 4,000, and this engine will rev to 7,700. 5 to 6 psi per 1,000 rpm is going to be pretty marginal for the rod bearings at these revs.
It could be that the oil is getting so thin that the pump is no longer in pressure relief. The oil pump being driven at crankshaft speed at 7000+ rpm probably doesn't help with pump efficiency or cavitation either.
With thinner oil, the pressure in the main gallery from the filter feeding point 14 will also be lower, which will decrease the feed pressure at point 14, and also have an effect on the dP across the point 14 restriction. So the dP effect across point 14 from thinner oil may not be much. Would have to run different flow vs dP vs viscosity conditions through a delta-p calculator model for point 14 to see how it would behave.For some of the restrictions in the system, like Point 14 above, the dP will increase with the square of flow rate, so they'll have a more pronounced effect on oil pressure with thin oil and high flow rates.
Subaru must have made the change for reason. Yeah, those pesky cornering G-forces starving the oil pick-up aren't a good thing.For the FA24 engine in the newer BRZ/GR86, Subaru used a larger oil pump. It's smaller in diameter, but has a thicker rotor, which I'm thinking might help it perform better at higher revs. That engine is better at holding pressure to redline (but only if you don't corner too hard and starve the oil pickup).
I'm trying to make sense of this.Here's a diagram. The flow does split off to one of the heads just after the oil filter, near the OEM pressure switch location. Point 12 would be where the crankshaft gallery pressure sensor would be located. Point 14 is the most obvious restriction, since the hole in the block is smaller than the piping on either side, introducing sharp-edged restrictions down to 11.5 mm diameter.
Are these rod bearing failures only on cars used for heavy track use? Are they running 0W-20 on the track (bad idea), and seeing high oil temps with 0W-20 ... or are they running thicker oil like 10W-40 and still having bearing failures?The recommended grade is 0W-20, and the oil can get a lot hotter than 90C. Rod bearing failures have been pretty common.
I'll throw something out there that might surprise you. You might be witnessing the effect of crank deflection. This may explain why the engines struggle to keep oil pressure at higher RPM with lower viscosity and why they fail rod bearings.
The FA20 crank has very little journal overlap, which is a huge contributor to crank stiffness. It also seems to have the journal centerlines pretty close together, there's very little space (and beef) between journals.
As a data point, contrast that crank with the Honda K20c1 (civic Type R), noting the massive thick web area between journals as well as how much more material there is around the crank journals themselves:
The oil pressure increases above 4000 RPM with the thicker cold oils because the oil flow is also increasing. The spring loaded pressure relief valve in the pump can not perfectly control the output pressure and flow, so there is still flow and resulting pressure creep even when the pump is in relief. Re: bold sentence. If the bearing clearance actually physically increased, the oil flow through them would increase, and the pressure feeding them (at point 12) would decrease. If the oil gets thin enough, the side leakage will increase which will have the same effect as increasing the bearing clearnce. Think of the journal bearings as mini scavenger pumps on the oil supply feeding them.Perhaps instead of asking where "the restriction" is, it's more useful to ask why the oil flow is increasing so drastically above 5000 rpm or so. After all, restriction is a function of flow. So when a fixed orifice seems to suddenly become very restrictive, it must be that that there's either the flow rate has drastically increased or the viscosity has drastically increased. We know there's no viscosity increase with temperature or RPM, so to me this points to a pretty large opening of bearing clearances due to inertial forces. That places a huge premium on hot viscosity to maintain oil pressure.
For the bearing clearance to change due to crank flex, the crank journal and the rod big end diameters would have to physically change size. If that was going on, I think the pressure vs RPM curves would be effected with all the oils shown. and you'd see more pressure roll-over for the top 3 curves than you see in that graph.If you are going to run those temps and those RPM, and engine like this probably needs a 10w60 kind of oil like you'd run in a Ferrari or Lamborghini or such. It necessary to overcome the large opening of bearing clearances under high rpm deflections when the oil is hot.
F1 engines also have a high volume oil pump and lots of oil coolers. The W rating of the oil doesn't really matter once the oil is hot, it's actually the HTHS viscosity of the oil inside the running bearings that has the most effect on the oil pressure.F1 engines have a rule-spec min KV100 of 2.8cSt, from what I can find online. But F1 engines are famously "tight" and as stiff and light as they can make the internals. The have no problem maintaining oil pressure all the way to insane RPM levels with an oil that's effectively thinner than most 0w rated oils.
So that's sort of why I'm thinking the FA20 has a crank deflection issue causing it leak oil like crazy at higher RPM.
The FA20 cranks have more overlap than the old EJ engines, and are said to be quite a bit stiffer. The engine block is stiffer as well.The FA20 crank has very little journal overlap, which is a huge contributor to crank stiffness. It also seems to have the journal centerlines pretty close together, there's very little space (and beef) between journals.
From what I know, it's more of an issue for tracked cars, which generally use thicker oil grades and often an aftermarket oil cooler as well.Are these rod bearing failures only on cars used for heavy track use? Are they running 0W-20 on the track (bad idea), and seeing high oil temps with 0W-20 ... or are they running thicker oil like 10W-40 and still having bearing failures?
The 0W-20 should have a KV100 of 11.8 cST at 185F, versus 7.9 cST at 225F, and 8.0/8.75 cST for the 10W-30/10W-40 at 245/265 F.Yeah, the RPM vs Pressure curves are a bit puzzling. For instance, the 0W-20 @ 185F curve is right in there with the other 3 lower curves up to 4000 RPM, so that means the viscosity is probably pretty close for all 4 of those oils, so it seems they would all track each other pretty close out to 7000 RPM, but the 0W-20 @ 185F keeps climbing while the other 3 roll-off after 4000 RPM.
Would need the specifics on each individual car to make any logical conclusions - multiple factors going on. Could be most of those cars that have bearing failures are due to the pump sucking some air (lack of lubrication) at times while on the track, and/or they are running too thin of oil for the use conditions.From what I know, it's more of an issue for tracked cars, which generally use thicker oil grades and often an aftermarket oil cooler as well.
They needed to record pressure at point 15 (right after the oil filter) along with point 12 over the RPM range with and without the oil cooler to see the effect. When there is limited recorded data (ie, just measuring the pressure at point 12), it's all just theories on what's causing the pressure roll-off at point 12 with thinner oils at above 4000 RPM.The oil pressure graph I posted came from a car with an aftermarket oil cooler. I've heard that they tend not to help at all with maintaining oil pressure, since the added restriction generally offsets the cooling benefit. I haven't seen a comparison with detailed data though.
Oil coolers have a quadratic dP-flow curve just like the other major restrictions between the pump and crankshaft, and so would also tend to drop the oil pressure a lot more in high flow/low viscosity conditions.
This stems back to my comments about what's going on in the rotating bearings could have an effect on the pressure at point 12. If the pressure at point 15 was also on the graph, it would help show if what's going on inside the bearings (ie, bearing MOFT, real time dynamic viscosity due to shear rate and side leakage effects) is directly effecting the pressure at point 12, which is on the downside of a restriction in the flow path (point 14). If the pressure at point 15 followed the same basic curve shape as the pressure at point 12, then I'd say the pump is lacking performance as the viscosity drops, and/or the oil cooler has some larger effect as the oil thins down.At 4k rpm, I think the reason that the pressure for the colder 0W-20 isn't much higher is that the oil pump PRV is coming into play at ~50 psi. With the thickest oil, we see the inflection point in the curve caused by the PRV at ~65 psi. For the next thickest oil, it's ~55 psi. For the 0W-20 at 185F, a more realistic extrapolation of the curve might show an inflection at ~45-50 psi at ~2,800 rpm. The oil pump PRV is cracking open at around 80 psi in each case, but the dP between the oil pump and crankshaft is increasing as the oil gets thinner and flow rates increase.
Colder oil is also less resistant to shear thinning, and this might be responsible for some differences in the shapes of the curves. The colder 0W-20 will start thinning at lower shear rates (lower rpm), whereas the hotter oils may not be shear-thinned very much at lower rpm, but may still end up thinning down close to their base oil viscosities by 7k rpm. The three different oil grades won't all be equally resistant to shear thinning either.
