Originally Posted By: Vikas
I just searched for "sludge" on Odyssey Forum on 2005-2010 models. The only reference I got was from somebody who read Trav's adventure with that particular Odyssey. That was the one which was claimed to have Mobil-1 every 7500. As far as I know Trav assured us that even though he did NOT personally did the OCI on that vehicle, he had no reason to doubt the veracity of 7500 Mobil-1 OCI.
The Odyssey forum is littered with blown transmission, I mean every other topic is "my transmission died, please help". As I said before, the only reference to the so called sludge problem was to the topic I mentioned above. He posted it as a poll and to get more data. Surprisingly, none of the participants in that forum came back and said that they found sludge in their engine. NONE.
Compare the pictures posted by the OP (10K OCI on dino) and by Trav (7.5K on Mobil-1). Tell me which one looks worse and then try to explain it rationally. You can't! Logically, if 7500 Mobil-1 caused that much sludge, OP's 10K dino would have solid grease under the oil cap! He does NOT even have CEL or any other engine related symptoms or drive-ability problems apart from the noise. That Odyssey had check engine light active.
I am not disputing that this particular Honda 3.5 VCM could have problems. HOWEVER, I am claiming that this is extremely isolated and not widespread at all. There is likely to be something else going on with that engine which is causing the issue besides the long OCI. Otherwise, the Internet would be littered with this problem like the typical Honda V6 transmission woes.
They all do that is NOT the right answer. The evidence presented so far does not lead to that conclusion.
Trav claimed it wasn't Mobil 1, and stated it was an un-named Group III lubricant. It is getting Mobil 1 going forward.
Why are you claiming it was Mobil 1?
Trav's thread:
https://bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2160571&page=1
Originally Posted By: Trav
How many times have we heard here that "varnish is only a cosmetic stain"? I was even told i had a fetish for believing it can be a nightmare for modern high tech engines.
Seeing as i have a 2005 Honda here with an all to common varnish/sludge issue that basically disables 3 cylinders when the VTEC valve sticks i decided to document it and share it here.
This engine had documented 7500 mi OCI with a major brand of synthetic oil, (i will not disclose the brand as it maybe taken as a bash,it is not.The issue here is with the engine design)The PCV had been serviced.
Yes 5w-20
but after we get it cleaned up Mobil 1 ESP 5w-30 will be used,this oil is recommended for this engine in the rest of the world.
I have done work to a few of these engines in Germany for friends of mine that were using the ESP for 15,000 KM (9K mi) OCI and none showed this kind of build up.
Be aware the one i did looked like just a varnish
issue until i pulled it apart then i found real deposits that nothing in a can could clean.
f i told you what i have tried and used in these Honda engines and what seemed to work best so far it would start a thin/thick oil war.
Mobil 1 0W-40
